08-11-2023, 11:18 PM | #1 |
Rep 1,319
MSS springs
So I had the MSS adjustable spring installed a month 1/2 ago and I really don"t feel the difference and I'm feeling the rear extremely harsh for the worst. It felt better on the stock height. I'm 100% thinking to switching (in the near future) with the KW V3 as I'm not liking the ride quality on the MSS.
DSC02984 by , on Flickr Last edited by Sayzar; 08-12-2023 at 01:32 PM.. |
08-12-2023, 04:52 AM | #2 |
DisplacementReplacement
440
Rep 1,131
This is interesting because some feedback has indicated a softer ride? You're saying a harsher ride, yes? How low did you go?
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
08-12-2023, 08:31 AM | #3 |
Rep 40
I’ve been told if you go all the way down you’ll be riding on the bump stops. Mine rides much better than stock (more comfortable). I’ll prob switch to KWv3 as I prefer a firmer ride and I can go lower with them
08-12-2023, 10:04 AM | #4 |
440
Rep 1,131
I'm on the fence between HR and MSS, still can't decide. I def don't want to ride the bump stops!
08-12-2023, 11:11 AM | #5 |
Rep 1,319
r33_RGSport13108.50 ThirstyX3M105.00 |
08-12-2023, 12:01 PM | #6 |
Rep 18,785
Did you guys switch the rear bump stop to the front and use the supplied bump stop on the rear?
Something is not right, the setup has been good and have a good feedback.
DBU234.00 |
08-12-2023, 12:22 PM | #7 |
Rep 1,319
Yeah, the supplied bump stop was installed in the rear. It' might just be me (thinking the ride is harsh) since I'm use to coilovers
r33_RGSport13108.50 |
08-12-2023, 12:24 PM | #8 |
Rep 18,785
Harsher than stock or KW V3 at soft setting?
08-12-2023, 12:48 PM | #9 | |
Rep 75
Drives: 2023 X3MC
Pic is the front. Can you tell from this that the MSS and not the OEM bump stop is on here? |
08-12-2023, 01:31 PM | #10 |
Rep 1,319
08-12-2023, 01:43 PM | #11 | |
Rep 18,785
The front would be easier to see once you jack up the front end. Also, if you have black bump stop, that would be the first original set. Did you buy it used? Edit: just realized that it is front shock, lol. Seems like OE bumpstop on the front. Now need to confirm the rear bump stop. Yea, something is not right. Not with the spring itself, seems like something wasn't done properly. The retail setup is not my personal X3MC setup where I purposely requested stiffer spring.
08-12-2023, 02:21 PM | #12 | |
Rep 75
Drives: 2023 X3MC
Here are better pics (as good as I can get without a jack at home). First 2 are front, third one is rear and then the kit you sold me. The black I was referring to were the MSS stops in the kit. The shop gave me back 2 beige OEM stops so I know they used the MSS ones. In these new pics the front looks like maybe the OEM beige are on there? So maybe they did it right? The harshness I get is over any speed bump or small/medium potholes a much harsher clunk/thump than stock. I get frequent rubbing in those situations in the rear with the 12mm spacers and chassis on comfort after spring install. Appreciate the advice! |
08-12-2023, 02:36 PM | #13 | |
Rep 18,785
Can you take a picture of the bump stop that the shop returned to you next to a ruler so I know what's the length? I'll check on Monday when I am at the office with my notes.
ztay201.00 |
08-12-2023, 02:49 PM | #14 |
Rep 75
Drives: 2023 X3MC
Thanks again. Pics of the returned bump stops.
08-12-2023, 03:25 PM | #15 |
Rep 18,785
It looks good.
Let me share this thread to MSS, maybe they have some input.
08-12-2023, 03:31 PM | #16 |
Rep 257
I've had both. The MSS is WAY to soft for me. If you lower it too much, the ride SUCKS as your right on the bumpstops. Takes the M out of the car. A lot of guys like them, to me personally, it takes the edge away from the car. I now have the H&R's. Ride is similar to stock, but it doesn't lower the car enough for me. I'm going back to the KWV3's I had on my 22 X3M Comp. Best of all worlds.
23 X4M Comp
21X10 21X11.5 Vossen HF5, 285/325 MPSS, H&R springs, 11mm Spacers, RK Tunes intake, Armorextend AE Design Carbon Fiber Front Lip, Rachip GTS Black with XLR, ALi Baba cat back, Carbon interior... |
08-12-2023, 04:57 PM | #17 | |
Rep 18,785
08-12-2023, 07:52 PM | #18 | |
Rep 109
r33_RGSport hooked me up w the MSS Kit and I can say it rides better than stock. I changed the setting to max low on the front and 15mm rear. No issues for me |
r33_RGSport13108.50 DBU234.00 |
08-12-2023, 10:08 PM | #19 | |
Rep 75
Drives: 2023 X3MC
08-13-2023, 03:18 AM | #20 |
440
Rep 1,131
Do you loose the electronic dampening and if so how does the truck deal with that?
08-13-2023, 09:07 AM | #21 |
Rep 109
08-13-2023, 03:24 PM | #22 |
Rep 689
Drives: 22 TR X3MC
Sub’d I’ve been experiencing the same as well in the rear too
2022 X3M Comp
2013 335i xDrive (Sold) |
