08-13-2023, 08:05 PM | #1 |
Rep 92
Coil Packs Corroded
Hello All!
After procrastinating for over a year and a half, I finally completed the dreaded spark plug swap. To my surprise, it was a lot easier than my friend’s E60 M5. My vehicle had been VERY sluggish lately and I realized that the spark plugs in place had probably around 40-50k miles. So on this very cool Houston day, I decide to swap them out. Most plugs seemed fine, however I did have 2 that literally had no gap, they were welded? together. I did also notice that on the passenger side, I had 2 heavily corroded coil packs and on the driver side just 1. Now I have no knowledge as to how coil packs work, I just know that they are essential to the car. My question is, why are some heavily corroded and others very lightly corroded? Did something drip in there? Given that my car is about to hit 65,000 miles, should I replace the corroded ones or just bite the bullet and replace them all? I put it all back together and she’s purring perfect. Performance is back, and she’s snappy as ever. If I do need to replace them, oem or aftermarket? I’m running stock with just aftermarket eventuri intakes; I intend to keep it this way. If I replace just the corroded ones, is it risky to mix aftermarket coil packs with oem? Any advice is appreciated! |
08-13-2023, 09:21 PM | #2 |
Rep 1,328
If these were from under the coolant tank, you have the dreaded (and occasionally motor fatal) coolant tank leak.
If that is the case, replace the tank IMMEDIATELY. More antifreeze dripping on there occasionally kills the engine. Shawn |
F30Andy1786.00 |
08-13-2023, 09:47 PM | #3 |
Rep 92
I've already been a victim of that. There was a little bit of dried coolant that I noticed when I swapped them. What is interesting is that the opposite side had more corrosion than under the expansion tank side.
08-13-2023, 09:51 PM | #4 | |
Rep 1,328
Maybe leftover from the failure? Shawn |
08-14-2023, 06:38 AM | #6 |
Rep 10,678
The coils have protective boots over the cavities they go in so theoretically they should not get wet. But in reality, they can. Could be condensation, could be water done how got past while washing the engine. I would not worry about a little surface rust on the coil bodies, but coils are relatively cheap so replace them if it makes you feel better.
What I found most interesting in the OP’s report was that the plug gap had diminished. It should get bigger. But the plugs seem to have something on them and I don’t know how to read it. Were they changed at 37k as scheduled? Last edited by pbonsalb; 08-14-2023 at 07:44 AM.. |
08-14-2023, 09:56 AM | #8 | |
Rep 92
I didn't realize how cheap these coils are. I will be replacing them with Dinan coil packs. |
08-14-2023, 04:38 PM | #9 |
Rep 132
I am thinking about them too. Although don’t have any reports of them on F90.
08-14-2023, 04:43 PM | #10 | |
Rep 1,328
Shawn |
