BIMMERPOST Universal Forums General BMW News and Cars Discussion Need help with tire size
      08-16-2023, 05:05 PM   #1
Whjohnson13
Drives: 2014 BMW 435i xDrive M-Sport
Hey All, I have a 2014 BMW 435i XDrive, I bought new wheels that are 19x9.5 (square set) I am currently running 19x8 (front) and 19x8.5 (rear). 225/40/19 front and 255/35/19 rear
I am trying to figure out what tire size would match sidewall size and work well with the new wheel size.
      08-16-2023, 06:14 PM   #2
Curently BMWless
Drives: 2025 M850ix on the way
If it was me, since you've gone to a non-staggered wheel size, I'd go to a non-staggered tire size, but buy one size bigger tire: 235/40R-19 front and rear.
You could certainly stick with the original 225/40R-19 size as well.
An even better place to ask this question would be the 3/4 series F30 tire and wheel forum. Click on the 4 series at the top of the page, then look down the page to find the wheel and tire forum.
'25 M850ix GC (Ordered)
BMW CCA 30 years
      08-16-2023, 10:56 PM   #3
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
There can be issues with AWD when changing the stock front to rear tire circumference differential. Usually it is increasing the difference that causes transfer case problems. Going square, I am not sure there is a problem, particularly if BMW has approved a square snow setup.
      08-17-2023, 08:17 AM   #4
Curently BMWless
Yeah, square should not be a problem at all. Square is the BMW-recommended winter setup.
BMW CCA 30 years
      08-21-2023, 06:54 AM   #5
jnbut
Drives: kia
Modifying the original front-to-rear tire circumference ratio might lead to complications in the all-wheel drive (AWD) system. Often, it's the increase in this difference that triggers challenges with the transfer case. However, when transitioning to a square tire setup, any potential issues remain uncertain. This is especially true if BMW has granted approval for a square snow configuration, indicating that compatibility concerns are likely addressed.
      08-21-2023, 07:49 AM   #6
Bc2005
Drives: 2021 M340i
In a BMW staggered setup the rear tires are wider/larger, but have a lower profile. The net effect is almost no difference in total tire/wheel circumference. The xDrive system will have no issues.
Llarry22406.00
      08-21-2023, 08:34 AM   #7
pbonsalb
Be wary of this new member — the 2 posts so far just take info from the thread and repackage it with some extra words.
