08-20-2023, 05:58 AM | #1 |
Rep 4
Drives: X1 U11 30e Msport
Which fuse location to use for Dash cam
I am wanting to hardwire my dash cam into the fuse box located under the glove box. Just wondering what location to use for this. Has anyone done this.
08-20-2023, 07:56 AM | #2 |
![]() 55
Rep 85
Do you have the built in 'Drive Recorder'? Mine has this feature, but it's not as good as a 'Dash Cam'. I remove my Dash Cam when I sold my previous BMW (X2), I still have it and was considering fitting it into my X1. There have been a few threads here on fitting one.
08-20-2023, 08:41 AM | #3 |
Rep 4
Can see one at present. Thanks
08-20-2023, 08:42 AM | #4 |
Rep 4
Thanks. I have this already but wanted to know what’s the best location to use from others experience. Thanks
08-22-2023, 07:02 AM | #5 |
![]() ![]() 51
Rep 119
I did it 5 months ago and it has been working fine so far. You can read the post #34 from mine in here:
https://u11.bimmerpost.com/forums/sh...1989840&page=2 |
08-23-2023, 01:52 AM | #6 | |
Rep 4
11-02-2024, 10:35 AM | #7 |
![]() 2666
Rep 2,636
Drives: 2024 M240ix BMW X1 28i
Is this located under or behind the glove box? If so, how did you access it? Also, what dashcam do you have and what fuse locations did you use? Thanks.
01-26-2025, 09:06 AM | #8 |
![]() 142
Rep 286
For anyone reviewing this thread moving forward I'll chip in with a pic of what I did for Ground option as there's very little metal in the area of the fusebox, passenger footwell.
I removed a plastic clip that was holding a single wire & installed a machine screw / nut setup thru that existing hole. Good ground obtained.
'25 X1 M35i w/M Sport Brake Option
Formally Owned: 2022 X2 S-Drive. Running 13mm Wheel Spacers & 255-wide 'go-flat' tires. 2011 X5 35d w/Sport Package 1986 528 |
