BIMMERPOST Universal Forums Classic BMW (Pre-2005 Models) Expansion Tank Hose O-Rings and Flanges
      08-20-2023, 06:36 PM   #1
NM8SHUN
Drives: 2003 Z4 3.0i
Hello,
New here, and haven't been able to quite find a thread that answers this. I'm hoping for some expert guidance.
I recently replaced the Coolant Expansion Tank. Newbie on the Z4 here, and I didn't watch very closely at the organization of the flanges and O-Rings as I removed the hoses from the old.
Now that I've assembled again, I've got a leak (presumably) where the hoses connect to the top of the tank and radiator.
I think that likely I've messed up the equipment that is on the inside of the hoses inside of the clip. It seems like there should be a hard flange (opening to the two male connections on the tank and radiator), and that there should be an O-ring between the flange and the rest of the hose.
Is this right?
The part I'm talking about is included in the attached photo.
Thanks for your help!
      08-20-2023, 09:00 PM   #2
John in VA
Drives: 2015 228i M Sport
If you car has the M54 engine the Z4 might have components similar to the E46. See:
https://www.e46fanatics.com/threads/...4-s54.1262447/
https://www.ebay.com/sch/i.html?_fro...mw+z4&_sacat=0
You can put the BMW part number into realoem.com & see what other models use the same part.
