08-27-2023, 12:14 PM | #1 |
Rep 19
Key Fob goes into sleep mode automatically?
Apparently the key fob automatically goes into sleep mode after 3 minutes of unactivity and there is no need for an RIFD blocker
So I was informed by the salesperson, but I have been unable to confirm looking through the literature and app. Has anyone else been told this? thanks brian |
08-28-2023, 08:17 AM | #3 |
Rep 19
08-28-2023, 07:15 PM | #4 |
Riding BMWs since 1977
132
Rep 518
So would that mean if you're walking around with it in your pocket it would continually wake up? Is the concern that it could be read/cloned by an RFID reader?
09-14-2023, 05:20 AM | #6 |
Rep 42
09-14-2023, 07:43 AM | #7 |
Rep 1,179
09-14-2023, 07:59 PM | #8 |
Rep 78
The car has Digital Key Plus that is UWB-based. As I already asked in different forum threads, we all need to figure out if a key fob is RFID, BLE or UWB. If it is UWB based - we all do not need to care at all about RFID blockers/readers and other key fob related theft subjects, because for now, it is impossible to hack it. I mean all is possible eventually, but the cost of the solution will be cosmically high and not comparable with any car cost or even jet.
UWB is using high frequency and wide spectrum for nanosecond pulsing signal that allows to detect key fob location and to track its movement real-time with centimeter precision. In simple words, imagine, you left the car and are going with the key fob to you home, then put the key fob on the shelf at home, all that was tracked and recorded by the car, the car knows the location of the key fob, the path how it appeared there and where to expect it next time. Then in 1 hour, you took the key, the key woke up, handshake with the car happened and the car compared the current location of the key with last recorded location, then you going to the car, all is tracked meanwhile and compared, and the car checks that indeed this key is moving to the car, and, with proximity of 50 cm, if all is good, the car triggers unlocking, then, when the key is physically inside the car, the car allows starting up. In fact algorithms are much more complex and encryption is applied on top. In fact, some UWB chips are using BLE just to do initial handshake between transmitter and receiver(like kickstarting) but this fact can be neglected as this is just to trigger UWB and all theft threatening things like unlocking or engine start is UWB based eventually like described above. So if key fob is UWB based - Relax And if it is not - we just all need to move to devices with UWB for comfort access. |
09-18-2023, 03:54 AM | #10 |
I Shoot People For Money
1047
Rep 1,917
Drives: 2023 Portimao MSport X1
I was under the impression that this was also possible with select Android based phones that had UWB chips as well?
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
U11sirgawain91.50 |
09-18-2023, 04:58 AM | #11 | |
Rep 153
My samsung Android is UWB fitted You delete your post (as misleading) , I delete this mine 😊
Ex320i, ex325ix, ex850i, ex530dTouring
09-19-2023, 09:58 PM | #12 |
Rep 65
U11sirgawain91.50 |
09-20-2023, 08:29 AM | #13 | |
Rep 42
https://www.press.bmwgroup.com/canad...x1?language=en Its written: Ultra-wideband (UWB) radio technology allows precision location pinpointing between the vehicle and the key or compatible smartphone. I guess, "or" means that the key also is UWB. I still cant understand why BMW leaves their drivers in the dark. If the manual doesnt state something, how one can know? These should be advertising candies also! |
JupiterOne38.00 U11sirgawain91.50 |
09-20-2023, 02:24 PM | #14 | |
Rep 78
