09-01-2023, 10:10 AM | #1 |
Rep 30
M-Performance Brake Upgrade - Spongy Brakes!
Just had my 428i brakes upgraded to M-performance brakes from stock BMW brakes non-msport. Brakes have been coded and bled 3 times yet i still have a bit of travel on them. Can someone please help me figure this out
Thanks |
09-01-2023, 03:15 PM | #4 |
Rep 10,319
09-01-2023, 06:12 PM | #5 | |
Rep 5,410
Drives: 2015 BMW 335i x-Drive Auto
https://youtu.be/o7XsCMqZXw0?si=aPG-jLvORlwxZW-s |
09-02-2023, 06:32 AM | #6 |
Citizen of ///M Town
73
Rep 83
My M-Performance brakes were spongy even though I bled them with Motive Power Bleeder. After taking it to indy shop to bleed with ISTA the problem was gone.
09-08-2023, 09:15 AM | #8 |
Rep 30
Hi guys
i've had the brake bleeding routine done through ISTA today and still the guys cannot locate the problem. The only thing i can think of now is do i need new master cyclinder? |
09-08-2023, 12:27 PM | #10 |
Rep 30
The full kit. I’ve already done about 1500 miles since they’ve been added on. The garage will try again next week with a Hydro Brake Bleeder Kit
09-08-2023, 02:47 PM | #12 |
Rep 499
What kind of pads are you using?
Unless you leave the brake lines open for extended period of time, the The ISTA procedure shouldn't be necessary (albeit can't hurt if done properly). The real reason the procedure exists is for master cylinder replacement. I clamped off my plastic brake lines while I painted my calipers and installed stainless steel braided cables once my calipers were ready and I don't have any spongy-ness. Obviously I immediately bled both sides of the caliper on installation. Also, no new DSC should be needed for the brake kit. |
09-09-2023, 05:06 AM | #13 |
Rep 1,124
During my VW days, they also cycled the ABS pump during a brake fluid flush. It's mandated in the procedure. I suspect it's the same for BMW dealers.
When I enquired as to why they do that, the VW master tech told it's to exercise the ABS pump pistons for a complete purge of every last scrap of old fluid. It's not just for master cylinder/ABS pump replacement. Sounds plausible to me because unless ABS, TC or DSC is activated during normal driving, the ABS pump doesn't do a lot, if anything, so rotten old dirty fluid can linger in there. |
09-24-2023, 09:50 AM | #15 |
Rep 103
This sucks I can bleed my Audis of the same year range with just pumping the brake pedal and a catch bottle and there is absolutely no air in my Audis. The BMW is different but I did mine and no air bubbles. I am still questionable about the outside valve first inside valve second thing since Brembo states to bleed the inner valve first.
09-24-2023, 11:20 AM | #17 | |
Rep 5,410
BMW M PERFORMANCE BRAKE KIT INSTALLATION INSTRUCTIONS https://rparts-sites.s3.amazonaws.co...Perf%20BBK.pdf |
09-28-2023, 02:54 PM | #18 |
Rep 119
I just had the coding done for my M Perf brakes on Tuesday, after originally installing a little while ago. Some of the sponginess remains, but the pedal travel-to-braking power is now far more linear, so it doesn't really bother me.
I want to have a shop install the Stop-Tech stainless steel brake lines before the winter, but I don't know if I'll get around to it. They're supposed to improve pedal firmness. |
09-29-2023, 07:50 AM | #19 | |
Rep 499
Wrt to pedal feel, its a bit hard to explain. The car definitely squats better under hard braking (makes sense, bigger rear calipers). The pedal isn't spongy or vague, but its not sensitive either. It took a little bit of getting used to but I have no complaints. |
co_440i120.00 |
09-29-2023, 10:48 AM | #20 | |
Rep 119
That's definitely a good way to describe the pedal feel post-coding. |
09-29-2023, 10:57 AM | #21 | |
Rep 499
Btw, I had a similar negative experience with ECS tuning, and for that reason, I won't order from them again. Their website listed the item as 'in stock'. A week later I had to contact them wondering why I hadn't gotten tracking info yet, and then they notified me the part was on backorder. I told them to cancel the order since they listed incorrect inventory status on their website (lead time was like 4-6 weeks) and they gave me a bunch of trouble over it. Eventually I had to initiate a chargeback against them. Absolutely terrible company. |
co_440i120.00 |
09-29-2023, 12:12 PM | #22 | |
Rep 128
However, after having a local shop bleed my 440, it's still shy of the feeling from my 335, so I started looking at parts numbers. If the car comes with 2NHA, at least for the 335, it'll have the master cylinder and brake booster that would come on the M3/M4. If you retrofit SPBR, it will be different, and the pedal will feel different, even with a pro bleeding it with much fancier brake fluid. I know this because I have the two cars parked next to each other, and I had just refreshed the 335s pads and rotors with OEM, and put all new on the 440, and can drive them side by side. The 440 is probably 95% of the way there, but I didn't feel like chasing the last 5% for a daily driver by swapper the MC and booster. But they are different. |
