09-01-2023, 10:33 PM | #1 |
Rep 4
Torque converter noise!!
Has anyone experienced this before? It only happens when the car is in D and at a stop with my foot on the brake and sometimes in R. It shifts fine with no problem. I either give it some gas or let off for it to stop. Video of sound
09-05-2023, 09:05 AM | #4 |
Car Hypochondriac
335
Rep 903
Drives: 2014 335i M-Sport Estoril Blue
PCV failure causes a squeal from the crank hub seal usually but maybe yours is coming from the rear main seal? Have someone open the oil cap when the sound happens, if it is PCV failure, the sound will stop.
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
09-06-2023, 07:38 PM | #5 | |
Rep 4
10-07-2023, 03:30 PM | #6 |
Rep 664
Drives: 2013 BMW 335i
Have you found the cause and fixed this issue yet? Mine just started making the exact same sound.
10-08-2023, 07:15 AM | #7 | |
Rep 3,958
10-09-2023, 07:46 PM | #8 |
Rep 666
It sounds like crankcase whistle more than the torque converter to me, and crankcase whistle comes from compromised PCV diaphragm, front main seal, or rear main seal. If you're really hinged in on torque converter side, then very likely the rear main seal is the culprit. I'm saying that because I believe that when your oil pan gasket is leaking pretty badly, it opens up the crankcase ventilation and you probably don't hear the whistle noise being too announced. Now that you've put on a new oil pan gasket and really sealed that part of hte crank case, the next leaky place will whistle during hard vacuum, namely, during idle when the throttle chokes the hardest. So in this case, rear main seal makes most sense.
If for whatever reason rear main seal isn't the cause of this and it has to be a guess with the torque converter side of things, I'd reckon either the flox plate is bent or torque converter is somehow binding and the tongue is gotta be rubbing somewhere on the bushing between the converter and the oil pump unit. But with this you should also experience some pretty bad shaking or rattling from the torque converter side.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
