09-02-2023, 09:03 AM | #1 |
Rep 1,137
OE HK speaker grill swap gone horribly wrong, help please!
Decided to take the plunge and swap the grills out, following these threads
https://x3.xbimmers.com/forums/showp...5&postcount=31 https://x3.xbimmers.com/forums/showp...0&postcount=39 Was super careful, took my time and everything was going great. Then I get to the rear passenger door, and this happens: F*CK ME! So now I need to find the part for the light assembly, see PDF. Need help, please. Any ideas where to find the part number? |
09-02-2023, 09:21 AM | #3 |
Rep 1,137
The numbers on the connectors are:
L3021194 C2354008E 2247700-2 5A37319-01 PBT-GF10 A8 Is this connector's color GRAU or VIOLETT? https://www.realoem.com/bmw/enUS/sho...diagId=63_2137 |
09-02-2023, 09:47 AM | #4 |
Rep 1,716
Drives: 22 X3MC MBB - C-17 Globemaster
Is it the long one across the door? or #9
09-02-2023, 10:14 AM | #5 |
Rep 7,584
Grau vs Violett. Simply google for a German to English translator & paste Grau then violett.
Off the top of my head gray=gray & violett=violet.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
pluckydks621.50 |
09-02-2023, 10:17 AM | #6 | |
Rep 1,137
Correct, violet. Found out that its not actually asking about the color of the assembly, but it uses the color of the connector on the door itself. goddamn why do they make things so complicated. LOL EDIT: found this. The color is actually of the LED itself, not the harness corrector on the door https://x3.xbimmers.com/forums/showp...&postcount=104 Last edited by TacosRule!; 09-02-2023 at 02:18 PM.. |
09-02-2023, 10:19 AM | #7 |
Rep 1,137
The long one that's at the top of the door, near the glass. There is a slight curve to the LED tube. From the diagram it looks to be #1 and #3 The local dealers are idiots and said the whole panel needs to be replaced. I call a dealer in Houston and they say that the part number for the connector on RealOEM do not apply to the car. The LED tube is correct (63316824242), still cant figure out the part number for the assembly itself (63319459825 or 63319459826). Gave them my VIN and said they would call back, but they were very uninterested... Last edited by TacosRule!; 09-02-2023 at 10:29 AM.. |
09-02-2023, 10:45 AM | #8 | |
Rep 1,716
Order both online? $120 |
09-02-2023, 11:52 AM | #9 |
Rep 1,137
Ok figured it out after calling a couple of other (competent dealers).
Parts needed are 63315a37319 and 63316824242, and of course since I have the shittiest luck imaginable, they're in stock in FL and CA, and since there were 'canes there.... |
09-02-2023, 01:28 PM | #10 | |
Rep 1,716
Check others online theres a huge warehouse in ohio and atlanta for BMW stuff. |
09-02-2023, 02:05 PM | #11 | |
Rep 1,137
Thanks for the tip. I checked atlanta and sure enough they have them, order placed. Also placed the order for the plastic fasteners since I need to grind off the rivets/plastic welds on the panel. Ugh |
thestimp990.00 |
02-18-2024, 08:35 PM | #12 |
Rep 4,035
I just noticed that the lower ambient light on my passenger side (RIGHT) rear door is out. So I've got this same problem. Wondering if I should order a new LED module AND the conductor assembly...
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
02-19-2024, 06:20 PM | #14 |
Rep 4,035
I'm no longer under warranty. It expired earlier this month. So I'll just buy the LED and/or the conductor on the lower portion of that door panel. Have to pop it off first to take a look under there. Hopefully it's just a loose connection.
02-19-2024, 06:28 PM | #15 | |
Rep 1,137
Ask your stealer, they may do a goodwill repair, its not long ago. But if they tell you to suck a lemon, then buy the conductors and connectors, both of them. Also get the screws and a small, accurate grinder for you to saw off all 20+ plastic welds. The connectors are locked in place by a small plastic tab that is part of the light element itself, so the connectors wont be lose, they'll be broken off. Its a very delicate connector, you'll see what I mean. I think I posted the procedures if not i'll send em to you. |
02-20-2024, 01:51 AM | #16 | |
Rep 4,035
95wildtt872.50 |
