09-02-2023, 02:48 PM | #1 |
Rep 2
Rims for BMW X7 M60i
Hello,
New to the BMW family and glad to be here. Have my old GTS brand rims used for winter on my 2018 Mercedes GLS550. Will it fit my 2024 X7 M60i or do I need to buy new rims again? Rim specs are 20x9.5 5/112 +35 66.5 Appreciate any help and info. Thanks. |
09-02-2023, 03:46 PM | #2 |
Rep 1,111
You might be in luck with your GTS's. I bought a set of Drag DR76's for my '22 X7 M50i, and the specs are 20 x 9, 5/112, +35, 66.56. If BMW didn't change the wheels going to the LCI M60i, you should be OK. You need to check the BMW OE lug bolt compatibility with the GTS's.
09-02-2023, 05:38 PM | #3 |
Rep 3,607
specs for the wheels should fit, but as streborx says, the lugs may be an issue. the lci uses the same centerbore and bolt pattern as all Gxx platform cars, ~66.6 and 5X112
M-B uses M14 X1.5 ball seat lugs bmw uses M14X 1.25 conical lugs you would need to find M14X1.25 ball seat lugs to go with the M-B wheels. not sure as they are aftermarket. length should be roughly the same.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC Last edited by Orient330iNYC; 09-02-2023 at 06:40 PM.. |
