09-04-2023, 10:48 AM | #1 |
Rep 2
For sale Two F30 F31 F34 LEAR TMS Headlight Module 7316186
$150 for both + shipping
Cleaning garage and found 2 TMS modules. Both work. 1 Original OEM RT Passenger side 1 New from Lear Lf or Rt. Original symptom was Adaptive headlight control malfunction. Replaced original OEM with used from ebay. Did not correct issue. Bought 2nd from Lear thinking ebay module was bad to. Went to replace with new Lear tms and found broken power wire. Couple months prior, ran something over and it cut a hole in the wheel-well cover which also cut the power wire. Once wire was fixed, issue went away. As stated, 1 was OE removed from rt side when issue started and is known working. 2nd is new from Lear and never installed. DM me if interested |
