bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW M2 Forums 2023+ (G87) Marketplace Classifieds Sponsors Classifieds
      09-05-2023, 12:11 PM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9599
Drives: G82 M4 / G87 M2
IND | RKP G87 M2 Enhanced Clearance Front Liner Set - V2
While BMW left plenty of room to lower the ride height of the new G8X M3 and M4, they unfortunately did not leave enough clearance between the front wheels and the front fender liners to adequately space out the wheels for an ideal stance. The result is a brand new M3 or M4 with wheels that look sunken into the fender arches.
The issue stems from the clearance between the front wheel and the cooling fins behind the heat exchangers mounted in the front bumper. In factory guise, trying to fit anything larger than 12mm spacers would result in rubbing when turning the vehicle. This was especially problematic in reverse as the downward angle of the fins would cause them to snap off when contacted by the tire.
The RKP front liner set includes both left and right front liners that have been professionally modified to enhance the clearance where the heat extractors are located. And since OE BMW liner cores are used, these modified liners will fit just like your factory liners.
NOTE: Installed photos show V1 mesh. New version includes honeycomb mesh. While these liners provide extra clearance whether using spacers or running aftermarket wheels, we cannot guarantee clearances with aftermarket wheel fitments and different tire sizes.
Product Details:
  • Includes both left and right front fender liners
  • Genuine OE BMW fender liner cores professionally modified
  • Original brittle plastic fins have been replaced with stainless steel honeycomb mesh with a black powder coat finish.
The RKP G8X M3 / M4 Enhanced Clearance Front Liner Set may be viewed at the following link to our online store:
https://ind-distribution.com/product...nder-liner-set
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
Sculpin278.00
g87
