09-08-2023, 07:54 AM | #1 |
Rep 694
I’ve asked in a couple threads and have searched others, but no success. Can someone clarify which G80 aftermarket front grilles avoid the need to shave the foam away behind the bumper when installing?
I’d like a different grille in the same vein as the CSL or GT3 styles, but I need: 1.) nothing that requires removal of foam or anything that I can’t undo and 2.) ACC compatible. I realize that may eliminate many or all options, but I wanted to ask. I’m leaning towards: https://ind-distribution.com/product...e2903a21&_ss=r Any help or advice is appreciated! |
09-08-2023, 08:52 AM | #2 |
Rep 1,356
if you don't need it to be carbon, i've got a replica CSL grille that meets all of those reqs and is about 10% of the cost of that autotecknic.
https://www.aliexpress.us/item/3256805149867676.html |
Chapter2099855.50 stangd1909158.50 |
09-08-2023, 09:32 AM | #3 | |
Rep 694
09-08-2023, 09:40 AM | #4 | |
Rep 1,356
I love IND and i buy a ton of stuff from them, but you should be aware that Autotechnik's business is quite literally sourcing stuff from china and taking nice photos of it for the US market. For this type of product it's worth looking into what you can get just buying direct - https://www.alibaba.com/product-deta...653710999.html |
09-08-2023, 10:51 AM | #5 | |
Rep 694
I can’t claim to understand the fabricating process, but it’s puzzling to me that there are wide spread fitment issues on many of these options. |
09-08-2023, 11:06 AM | #6 | |
Rep 2,765
Drives: 2024 M4 Convertible
I get that you don't like this practice, but that's of value to people, including me. |
luckym3girlnj815.00 |
09-08-2023, 04:18 PM | #7 | |
Rep 751
The Stradale - absolutely abysmal fit out of the box. The top of the forward bumper was shaved in a second attempt to get it to sit correctly. Still didn't fit. The Vorsteiner CF - didn't require shaving (it was already shaved from the Stradale, but I don't think it was a factor either way). Couldn't get the PDC sensors to function correctly. Actually attempted to replace this one with another Vorsteiner CF grill and the PDC sensor mount broke before we even installed it. The Vorsteiner ABS - completely removed the forward foam bumper. This is likely the least destructive way to do it. Alternatively you need to cut major recesses into the foam to accommodate the PDC sensors. As far as why... for the Stradale, it was an absolute abysmal fit even with shaving the bumper. The Vorsteiner ABS sits further back in the grill hole than any of the others that I used. All others pretty much sit flush with the front of the bumper cover, but the Vorsteiner ABS is inset into the grill hole. This is why there is so much interference with the foam bumper for the PDC sensors. The first picture is the Stradale before shaving the bumper, it is sticking out at the top. Once we shaved it, and used two layers of 3M double sided tape it fit only just a little better. The second picture is the Vorsteiner CF grill. Notice the PDC sensors are removed. That's because they wouldn't stop going off. The last is the Vorsteiner ABS. Notice how far back into the bumper the grill sits. When I was first looking at the various grills, I wanted a flush mounted grill. But, now that I have the Vorsteiner ABS I *really* like the inset look and the ABS look. One last note: of the three, only the Stradale can accommodate the full M4 Competition badge, which is why I went with it in the first place.
Perf: Carbahn Stage 2, Eventuri Intake, PSI Midpipe, Remus Race Exh
Susp: Turner Skid Plate/Strut Brace, KW v4, F-L Monoball, MS: Camber Plates, Spacers, SPL Rear Cosmetic: MPerf: Splitter, Side Vents, Sill Plates, Door Projectors; IND CF Roundels/Float Center Caps, Vorsteiner Grill, Xpel: Stealth PPF, Fusion Plus Ceramic, XR Plus 5/20/70 |
jad4ca3.50 Chapter2099855.50 |
09-08-2023, 04:25 PM | #8 | |
Rep 2,391
Formerly Wyndi335I
2009 BMW 750li sold 14 BMW X5 04 BMW X5 11 BMW 335i convertible (sold, sellers market |
09-09-2023, 09:16 AM | #9 | |
Rep 694
Hat goes off to you for working through all of that. Sounds ridiculously frustrating but your current Vorsteiner does look really good. Thanks again for the post. Helps quite a bit. |
m4ml1895.00 |
09-09-2023, 09:25 AM | #10 | |
Rep 694
JDUNITNOW3595.50 |
09-09-2023, 07:46 PM | #11 |
Rep 2,391
Yep.... thats why I decided to do it. Personally, I like the Vorsteiner grill the best.
Formerly Wyndi335I
Chapter2099855.50 |
