09-13-2023, 02:08 PM | #1 |
Supreme Allied Commander
3886
Rep 54,503
Drives: F80 M3
Ohlins Road & Track Coilover Suspension BMW G87 M2 BMS MW00S1
DESCRIPTION
A more than 40 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises is over. All shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a worldwide 2-year limited warranty on all of our products. GENERAL FEATURES: Patented DFV technology (Dual Flow Valve) Individual height adjustment Rebuildable Corrosion salt spray tested (ISO 9227) 2 year warranty Approx. 10 kgs less weight compared to standard suspension FEATURES FRONT: McPherson strut, upside down Compression and rebound damping with one adjuster Spring preload adjuster Separate length adjustment Approx. 25 mm lower than standard with recommended setup Spring rate 100 N/mm Use with original top mounts FEATURES REAR: Conventional shock absorber Compression and rebound damping with one adjuster Spring preload adjuster Separate length adjustment Approx. 20 mm lower than standard with recommended setup Spring rate 190 N/mm Use with original top mounts PURCHASED PARTS PACKAGE: Coil over kit incl. springs and mounting parts C-Spanner (for spring preload adjustment) Owners manual and mounting instruction Sticker set EDC CANCELLATION KIT: 35020-33 Cancellation kits are not included and need to be ordered separately. FITS THE FOLLOWING VEHICLES BMW G8X M2 M3 M4, YEAR 2020 – Type: G8X Variants: 2WD TUEV certificate in preparation Manufacturer confirmation (SUI) GOCA in preparation (BE) Not for 4WD models (xDrive) $3190 Order here: https://hpautosport.com/product/ohli...ve-bms-mw00s1/ Please feel free to contact us for quotes on Ohlins for other vehicles. We carry the entire line of Ohlins R&T, Track Day, and TTX. Last edited by HP Autosport; 04-26-2024 at 01:31 PM.. |
09-30-2023, 11:36 PM | #5 |
3886
Rep 54,503
Drives: F80 M3
Custom Swift springs available for your street-driven M2 available. Feel free to PM us with any questions you might have.
10-12-2023, 01:52 PM | #9 |
3886
Rep 54,503
Drives: F80 M3
PM for a bundled price with Voshlag camber plates! All in stock and ready to ship!
10-17-2023, 02:54 PM | #11 |
3886
Rep 54,503
Drives: F80 M3
These are shipping now.
PM, email or call us if you want custom spring rates for a better ride on the street. |
11-17-2023, 08:44 PM | #21 |
3886
Rep 54,503
Drives: F80 M3
PM for Black Friday deals on Ohlins R&T, Vorshlag camber plates, AP BBK, SPL, or anything you can think of!
