09-13-2023, 06:36 PM | #1 |
Rep 33
Radar Detector Mirror Wire Tap Question
Can anyone help with mirror wire tap install for a radar detector? I don't have a multimeter and I'm curious if somebody can let me know what colors are the power and ground?
Install seems simple and straight forward after watching a vortex video, but if there are any details I might be missing before getting into it, that'd be helpful as well. Thanks! |
09-13-2023, 06:38 PM | #2 |
Rep 82
I used this video, only difference is the mirror is a bit different https://youtu.be/JKvhcmoAHnE?si=WXrFgYpHKFmre-zD
twenty2twos37.50 GHO$T20.00 |
09-14-2023, 12:09 AM | #3 | |
Rep 29
To the Windshield using the Tape, or off the Mirror with a bracket like a Blend mount ? |
09-14-2023, 08:03 AM | #4 | |
Rep 33
Since my windshield is tinted and I do a lot of city driving, I decided against having it on the windshield. I bought a cheap mirror mount, but I’m expecting to not care for it. I actually have something that seems to work really well. For my golf bag I bought this stick it setup for my range finder and the plate (link below) is the perfect piece to go on my visor and have the single suction stick mount on it. STICKIT Golf Bag Metal Landing Pad I Metal Bag Clip for Quick and Easy Use of Magnetic Golf Gear & Accessories with Convenient Positioning on Your Golf Bag https://a.co/d/breJTHc It’s easy on and easy off with no mount sitting there empty when not in use. Also sits at the perfect angle and is just the right snugness on the visor. I was hoping the magnetic strap from Stick It would work as well, but the single suction fits perfectly and its low profile enough that it adds very little drop when on the visor. I’ll take some pictures when I get a chance. One concern was being able to comfortably see the screen on the detector but the one I have is connected to an app, so now it’s about finding a good spot for the phone, or just having it audibly tell me what I need to know. Still toying around with ideas though. |
GHO$T20.00 |
09-17-2023, 02:54 AM | #6 | |
Rep 71
Drives: m2
twenty2twos37.50 |
09-17-2023, 12:46 PM | #8 | |
Rep 71
Drives: m2
09-17-2023, 08:45 PM | #9 |
Rep 33
The idea is to wire tap it into the mirror, just haven’t had a chance to do that yet. Just got back from a wedding about 3 hours away and no complaints from my girlfriend about the cord. Once it’s wire tapped, it should clean everything up nicely and I like the fact that I don’t have to have it out all the time since I do a ton of in town driving. |
09-20-2023, 03:22 PM | #10 | |
Rep 929
Drives: 2019 F87 M2C, 2023 G87 M2
09-20-2023, 09:51 PM | #11 |
Rep 132
Getting that plastic housing around the mirror was the most difficult part. I actually used a really large flat head screwdriver but I don’t recommend that. Spend a few bucks and use plastic trim tools. Put it in between the two panels and twist. It should pop open. Try YouTubing M3/M4 hardwiring videos as they have the same style plastic housing as the M2
10-31-2023, 08:41 PM | #13 | |
Rep 13
quick question, how long does it take for your radar to shut off? Im planing on getting mine car end of November and this is the first thing I want to do. Also did you plug both in the black one for one in each? (black and purplish connector) Thanks! |
10-31-2023, 09:17 PM | #14 |
Rep 82
About 5-10 mins after shutting car off. No, one goes in brown and another in red I believe, it was shown in that video and it was the same for me
eppicspeed30.00 |
11-01-2023, 04:43 PM | #16 |
Rep 13
ya. I just saw this video. If you skip to 2:54, you can see that they had a hard time and they show where all the clamps where as well as the wires.
11-02-2023, 10:31 PM | #17 |
'Sirius' - 2024 G87 M2 in Black Sapphire
69
Rep 43
I did the Uniden R7 radar install today on the G87 using the Mirrortap cable. I mounted this setup using the blendmount for uniden. The mirror tap process was fairly simple but I ended up tapping into the rain sensor cable (pink) instead of the homelink cable (black) by connecting red to red and black to brown. However I accidentally shorted the automatic lighting system during the process and lost all power to the rain sensor. Ended up tracing the fuse to the F3 fuse in the BDC fuse box (passenger footwell, need to remove the trim near the right of the passenger feet to access it) and replaced it with a new 7.5amp fuse. That fixed the malfunction and everything was working again. Enjoying the zero cable look so far 👌
eppicspeed30.00 twenty2twos37.50 |
11-13-2023, 06:21 PM | #18 | |
Rep 175
I'm not even sure what option I might have that would possibly make my car any different. I do have a blinking red alarm light in my rear view mirror that never shuts off. I don't know if that is the same with others? If anyone has any insight to this please let me know. I've left my plastic disassembled until I get the dash cam install sorted, but I would really like switched power for the radar. Thanks |
11-14-2023, 10:34 AM | #19 | |
Rep 175
Thanks for this very odd tip on how to make it work. |
11-20-2023, 02:11 PM | #20 | |
Rep 130
