09-15-2023, 04:14 PM | #1 |
Rep 259
Brake pads not making full contact
I had my calipers powder coated last week, so we reinstalled them and bled each caliper twice and still getting a soft pedal.
Powder coater pressure tested each piston before return and all was good. Should we bleed again? |
09-15-2023, 04:17 PM | #2 |
Rep 259
I’m trying to post a picture to show rust marks on the rotor to show the pads are not making full contact.
What app are you guys using to post pics on mobile? Thanks! |
09-15-2023, 05:25 PM | #3 |
Rep 8,524
Pictures of the callipers and the pads would be useful.
There’s a long list of things to check :
Are you experiencing soft pedal but good braking performance, or has braking been reduced as well ?
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
09-15-2023, 08:18 PM | #4 |
Rep 259
Yes, master cylinder was topped off
We used brake line clamps while the calipers were off We have not, I only went by the powder coater saying all pistons were pressure tested Good to know Braking performance is the same, I just have to put the pedal between 1/2 way and the floor. When I hit the brake initially, let off slightly (not all the way) and hit the brake again, the pedal is back to normal if that makes sense. Appreciate your response. |
09-15-2023, 09:26 PM | #5 | |
Rep 16,197
You post photos using a photo hosting website, or your own website if you have one. |
09-15-2023, 09:49 PM | #6 | |
Rep 259
Yes, I know that. I am asking what app are people using to get the url for a picture. This is the only forum I know where you have to add the url. I used to use tiny pic to post pics on here, but they went under years ago. |
09-15-2023, 10:16 PM | #7 |
Rep 1,372
Not making contact with the rotor seems like an odd problem. The pistons exert a significant force so if something is resisting that force, it must be significant.
How new are the pads? Do you have any old pads? The idea here is with either worn pads or by removing the caliper you want to test how well the pads will slide along the caliper pins without the use of the piston. There are two flat spots, top and bottom, roughly 10-15mm wide that keep the brake pad from moving up and down but do not hinder it's motion in and out with respect to the rotor as it slides back and forth along the caliper pins either when the brake is pressed or when it is released. There should be no binding. The pads cannot get stuck. Keep in mind, the top may bind while the bottom remains free and visa-versa. This will cause the pad to touch the rotor at an angle. I think this possibility is remote since the powder coating people should know about these flat spots (4 in total, 2 left, 2 right) and avoid coating them but there is always a 'new guy' who rushes and makes an error. If there is no binding of the pads along the length of travel of the caliper pins, look into using ISTA to bleed the brakes. ISTA has a procedure to activate ABS and shake out any stubborn bubbles a normal bleed would not be able to free up. Good luck
340i xDrive (F30), 228i (F22), 320 (F30), 325i (E46)
09-15-2023, 11:15 PM | #8 |
Rep 5,410
Drives: 2015 BMW 335i x-Drive Auto
A common issue that results in a soft brake pedal is to bleed brakes, but fail to follow the ISTA procedure which makes sure to vibrate off all of the air bubbles clinging internally to brake components.
Video by FaRKle! https://youtu.be/o7XsCMqZXw0?si=we1BEosPHoWaK3El |
daryl rsv452.50 |
09-16-2023, 02:44 AM | #9 | |
Rep 8,524
daryl rsv452.50 |
09-16-2023, 04:39 AM | #10 |
Rep 259
Here’s a pic of what I was explaining with the rotor. This was with driving about 10 miles after the 2nd bleed.
09-16-2023, 06:13 AM | #11 |
Rep 8,524
That just looks like normal/common scoring of the discs.
Have you allowed enough time for ghee new pads to mate to the discs, and/or properly bedded them ? A new flat pad being pressed against an uneven disc surface will initially result in reduced braking performance untill the surfaces have fully mated.
09-16-2023, 08:17 AM | #12 | |
Rep 259
We used the same pads & rotors because there was plenty of meat left. Look closer at the rotor, pads are definitely not making full contact. |
09-16-2023, 08:39 AM | #14 | |
Rep 259
We’ll be working on the brakes again this morning and we’ll give this a try. Thanks for posting! |
johnung4552.50 |
09-16-2023, 03:27 PM | #15 |
Rep 15,858
daryl rsv452.50 |
09-16-2023, 03:50 PM | #16 |
Rep 8,524
Bearing in mind that the BMW MPerformance calibers are 6-pot units, and that the outer pistons align with the wider radius of the swept area, I'd check that these outer pistons are extending correctly.
daryl rsv452.50 |
09-16-2023, 04:02 PM | #17 | |
Rep 259
Good point, I’ll check that when we pull the wheels off. Pretty sure we did, but I’ll definitely check. Thanks! |
09-16-2023, 04:03 PM | #18 |
Rep 259
09-19-2023, 05:57 AM | #19 |
Rep 1,372
Is there any sound of scraping, like the rotor is making contact with something, when you drive?
09-19-2023, 06:13 AM | #20 | |
Rep 1,328
Shawn |
09-19-2023, 08:42 AM | #21 |
Rep 16,197
Those rotors were scored before the pads were changed. They should have been refinished before putting on the new pads. Over time the new pads and rotors will break in to each other, but they'll never be perfect. I'd pull the rotors and refinish them to flat.
Polo088161616.00 |
09-19-2023, 08:58 AM | #22 | |
Rep 15,858
I'd second what you say, if it was new pads on old rotors. It is why I suggested the pads were put back in different positions. Now trying to bed pads to different friction faces. |
