09-25-2023, 10:08 AM | #1 |
Rep 85
F20 n13 cylinder 1 connector issue?
hello I need help.
my N13 F20 has been facing misfire issues over the last year. summary: did a plug change 2 weeks ago and misfire was gone during driving but appears a little bit during idling. 1 week after, misfires+rough idle+vibrating+engine light turn on+drivetrain error when cold start.but this goes away when i restart the car then I got hit with the same thing but this time while driving and it did not go away after restart. did a coil test by unplugging the connectors with engine on and cylinder 1 was the problem but after swapping coil position it was always cylinder 1 so definitely not coil or plugs. noticed the connector on cylinder won't plug in nicely, using force results in a very hard feedback and it won't sit tight no matter what. possible connector issue? can't find anyone that faced a connector issue on bmw forums so seems like it's unlikely but possible? codes ive pulled had always been "cylinder burning time outside tolerance and cylinder misfire" |
