10-15-2023, 09:54 AM | #1 |
Rep 471
Drives: Yes
Folks with square 19x10.5 VS-5RS: How's your fitment?
Id like to run square 19x10.5s on 295/35 PS4S tires. Completely stock suspension for now. Will I need spacers? I know there will be some fender rubbing, I’d consider the aftermarket liners if they solve the problem. I’m asking because I’ve seen posts recommending 5mm spacers and others with no spacers (but with camber plates). Not sure if one or the other is a must.
I’d like to hear from others before I pull the trigger on the wheels. Thanks! |
10-15-2023, 01:02 PM | #2 |
Rep 268
I have 19x10.5 with 295/30/19 with no spacers and I have zero rubbing in the fenders. There is about 5-10mm clearance between the tire and the strut.
Keep in mind that 295/35 tires will be about an inch larger in diameter than mine and about a half an inch larger than stock.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
10-15-2023, 01:19 PM | #3 | |
Rep 471
Drives: Yes
10-15-2023, 02:19 PM | #4 |
Rep 268
Camber plates won't affect the gap between the tires and strut but it could between the tires and the fender. I have had my camber set to factory and -3 and still didn't experience any rubbing.
2022 M850i
12-25-2023, 07:39 PM | #6 |
Rep 471
Drives: Yes
Right now I’m in my winter setup which uses 275/35 tires, but come springtime I will be swapping for 295/30s.
There’s a few members on the forum with that setup who say the fitment is perfect. |
