10-18-2023, 09:01 AM | #1 |
BimmerPost Supporting Vendor
3933
Rep 3,136
NEW PRODUCT RELEASE: Dinan G8x M3/M4 Adjustable Coil-Over Suspension System (HAS Kit)
Part Number: D190-8210 Applications:
Release Date: Available Now! Description: For the driver that demands the best out of their vehicle. The Dinan Adjustable Coil-Over Suspension was bred in the race lab but refined on the street for maximum versatility. No matter the environment, the traction that is awarded to the vehicle from the improved suspension will inspire newfound confidence when running at higher speeds. From the substantial reduction in body roll as well as reduction of dive under braking and squat under acceleration, Dinan guarantees you superior handling, performance, and comfort. Dinan's design retains the superb factory electronic shocks but swaps the springs to a more aggressive, performance enhancing formula and implements threaded collars that allow the user to change the ride height themselves. While shorter, stiffer springs are commonplace in aftermarket suspensions and are a key element in reduction of body roll it is not a one size fits all approach. In the case of the G8x M3/M4 where the vehicle has a penchant for oversteer, stiffening the rear springs would exacerbate the problem of the rear losing traction before the front when the platform is pushed to the limit. Dinan instead has opted to soften the rear spring rate as well as switch from the factory progressive rate rear to a dual rate spring setup. The combination increases predictability and compliancy, and in turn, provides better rear grip/road holding for a vehicle that needs both. The result is a sleek lowered stance that provides improved handling to go along with its stunning visual appearance. The springs combined with progressive bump stops and other components increase travel that allow the car to be lowered up to 1-1/8" in the front and 2-1/4" inches the rear. However, to retain the ride quality synonymous with Dinan suspension kits the recommended drop of 3/4" (M4) or 7/8" (M3) in front and 3/4" in the rear is advised. For suspension connoisseurs, or those that are just simply very particular, suspension packers are included to fine-tune handling and comfort by changing the clearance of the progressive bump-stops --- something no respectable race car is without. Features/Benefits:
10-18-2023, 11:24 AM | #3 |
Learning to drive again
792
Rep 351
Drives: M3CS
One of the things I always liked and respected about Dinan was that they produced products based on testing and finding the optimal approach. It appears they have done so again here. Compared to all other products, I do trust Dinan far more.
Well Done!
Cheers,
BoB |
Dinan_Engineering3933.00 |
10-18-2023, 12:48 PM | #4 |
Rep 640
Look forward to seeing feedback, I plan to install a HAS kit and this looks like a top contender. Particularly with the reputation Dinan has.
2024 M3 CompX Dravit Grey - MP HAS - Millway - MHC+ carbon - CS software - MAD single-mid - PPF
2019 G05 X5 x40i, built 2001 600whp B5 S4. |
10-18-2023, 02:15 PM | #5 |
Rep 1,955
1" lowering in the front and 2.25" in the back? Shouldn't the fronts have more adjustability since they sit much higher than the rear?
Laguna01///M31400.50 |
10-18-2023, 03:38 PM | #6 |
3933
Rep 3,136
The amount of lowering is dependent on the amount of threads available on the threaded sleeve based on initial position of the spring perch that targets Dinan reccommended ride heights. Simply more threads available on the rear as a result of that process. That said, in order to hit 2.25" inch of lowering in the rear you would be burying the bumpstop so in actuality would need to remove it when looking for that excessive rear lowering. With the bumpstop in place its more in the realm of 1.75" of maximum lowering in the rear.
10-19-2023, 06:15 AM | #8 |
3933
Rep 3,136
10-19-2023, 10:45 AM | #11 |
Rep 6,919
what's the price on this kit?
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
10-19-2023, 09:21 PM | #13 | |
Rep 1,955
