E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > problem with my Hamann quad system install???
Reply
      05-23-2006, 04:19 PM   #1
HSU
HSU's Avatar
36
Drives: 330i Awhite/terra
e46 m3  [0.00]
V10 M5  [0.00]
2006 330i  [0.00]
2003 C coupe  [0.00]
anyone knows whats problem with my Hamann quad exhaust install ??? I was happy with my hamann exhaust finally arrived but exhaust shop just told me they wont fit my e90 without any cutting welding ??I thought I spent 3 g they are bolt right on? hope someone had experienced for exhaust system installed Help me out on this?.......thanks in advance
      05-23-2006, 04:31 PM   #2
HSU
HSU's Avatar
36
e46 m3  [0.00]
V10 M5  [0.00]
2006 330i  [0.00]
2003 C coupe  [0.00]
last 2 pics How exhaust shop said problem is.......
      05-23-2006, 04:36 PM   #3
EVO_S4
EVO_S4's Avatar
117
Drives: 2016 M3
2016 BMW M3  [0.00]
2009 BMW  [8.24]
really $3K and it doesnt fit perfect, good luck to you in getting it resolve
2016 M3
2016 Audi Q5 3.0T
      05-23-2006, 04:40 PM   #4
HSU
HSU's Avatar
36
e46 m3  [0.00]
V10 M5  [0.00]
2006 330i  [0.00]
2003 C coupe  [0.00]
I ran two local shop they all same answer still waiting response from Hamann
      05-23-2006, 05:46 PM   #5
MIKEYMIKE
MIKEYMIKE's Avatar
Drives: 330i 6mt
Wow, 3 g's aint cheap. Good luck man
      05-27-2006, 04:18 PM   #6
strykr
Drives: 06 325i
Speak to carrozeria design, they had the full hamman exhaust on their silver e90. They might be able to provide you with some insight.
      05-27-2006, 07:06 PM   #7
ward
Drives: F
that looks way better than the eisenmann!
at least the second pipes are not on flexy tubing!
      05-27-2006, 10:20 PM   #8
HSU
HSU's Avatar
36
e46 m3  [0.00]
V10 M5  [0.00]
2006 330i  [0.00]
2003 C coupe  [0.00]
just found out this might help I belive Hamann made by supersprint getting front pipe hopefully work out
      05-27-2006, 11:20 PM   #9
LWL
LWL's Avatar
Drives: G05 X5
Hey,
I got the Kerscher quad exhaust and I had similar installation problem like you have now. The problem is the german version and US version's catback setups are different. The ending of the catback for mine is exactly like what you have. My shop needed to cut and re-adjust the positioning of the catback pipe so that two pipes would have wider gap between them to fit the resonators' gap.
I posted pictures adn comments on this issue on two different posts. The following link went to one of my post that shows the modifying part of the catback on my car. They cut and welded the endings. http://www.e90post.com/forums/showth...light=kerscher
I guess you will probably need to pay more for the shop and do the modification for you, unless you can get your seller or Hamann get to pay you. Good luck.
      05-28-2006, 12:16 AM   #10
HSU
HSU's Avatar
36
e46 m3  [0.00]
V10 M5  [0.00]
2006 330i  [0.00]
2003 C coupe  [0.00]
thanks alots its really help
Originally Posted by LWL
Hey,
      05-29-2006, 01:49 AM   #11
Pretender
Pretender's Avatar
150
Drives: 06 330i, 07 328i, 16 X1, >17M2
06 330i  [0.00]
I have the Kerscher exhaust and it's the same as yours. What I'm going to do and I would recommend to you is cutting the left pipe and turn around and clamp it. Then, you just have to weld 1 pipe to the resonator or use an adapter to connect instead of welding both pipes in LWL's case (4 weldings total) :
It's a great time to be alive
Reply
e90post
