BIMMERPOST Universal Forums Classic BMW (Pre-2005 Models) BMW X5 E53 2006 Battery drain
      10-23-2023, 06:06 PM   #1
X5Richy
RichyX5
Drives: X5 E53 2006 3.0d
Hi Everyone,
My car was all okay for a year, has a near brand new battery
It now goes flat after 2 weeks, so I hooked up amp meter to the negative terminal off battery and to the negative battery post
Draws 5.3 amps initially then something goes into sleep mode and drops to 3.3 amps
I traced to the panoramic sunroof fuse 58 without this fuse only draws 0.3 amps
But the drain isn't on the feed in side it's actually after the sunroof ecu on the pale brown wire next to the red / green strip wire ( the 2 thickest wires) I have headlining and seats out atm so thought I'd try to track down
The pale brown wire looks like it goes down the Right hand Drivers side A pillar, I found a wire that goes under the seat to somewhere but I'm really not sure if it goes anywhere else or if its the same wire. Can pull all other fuses out and it doesn't make any difference on Amp draw
Hope someone can help me trace it
      10-24-2023, 07:48 PM   #2
John in VA
Drives: 2015 228i M Sport
Try https://xoutpost.com/bmw-sav-forums/x5-e53-forum/
Good luck!
