10-26-2023, 05:04 PM | #1 |
![]() ![]() 101
Rep 121
Ceramic wheel coating
Has anyone tried ceramic coating their wheels to stop brake dust from building up? I use a ceramic spray coating every few months on my car's exterior bodywork (provides nice protection to everything except the glass). Water rolls off and dust/bird droppings/ other crap just doesn't stick so I wonder if it would work on the wheels as well to stop brake dust from building up? I also see dedicated ceramic wheel cleaners for sale for around $30, do these work any better?
10-26-2023, 05:49 PM | #2 |
![]() 146
Rep 177
Drives: BMW X5 xDrive40i
I believe the face of my wheels had ceramic applied in the package I purchased from the dealership (CeramicPro, separate shop).
If it helped, I feel sorry for those without. Brake dust is pretty significant and requires hand wiping every surface. I know. I’m not special. Welcome to the club. |
10-26-2023, 05:55 PM | #3 |
![]() ![]() 5074
Rep 3,859
A coating will not prevent brake dust but will make it easier to remove. A high quality hand applied coating is the only thing worth doing on the wheels.
Westside Guy7694.50 ultrared93112.00 |
10-26-2023, 06:33 PM | #4 |
![]() ![]() ![]() 518
Rep 473
Drives: F80 AW 6MT
Yes, I had my R101LW in Gloss White ceramic coated and the brake dust didn't want to stick on. Made it super easy to just wipe the dust off. I also switched to PosiQuiet ceramic brake pads, and made it so my wheels were pretty much clean at all times. I'm still running the same type of pads 6 years later.
Gabe - F80 AW Cloth 6MT - HRE 520 - OEM GTS Hood - Recaro Pole Position - CS lip/spoiler/diffuser - Status Gruppe SRS Coilovers - Nose Lift - Full Suspension - OEM Alcantara & Carbon interior - BM3 - IKON ![]() |
dnachmerp16.00 |
10-26-2023, 06:44 PM | #5 |
YNWA
![]() 1260
Rep 979
I know the coating helps resist brake dust sticking to the wheels because as I drive, brake dusts falls down to the bottom of the wheel when I park. I can blow most of it off with air.
I use an iron remover type wheel cleaner spray which tackles the rest. At worst, a very light layer of dust remains, and I have to "touch" the wheel with a brush or mitt - though I only do that every other wash. Other benefit, besides looks, are hydrophobicity for reduced water spots and ability to blow dry the wheels clean/dry.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
10-26-2023, 07:03 PM | #6 | |
![]() ![]() 101
Rep 121
I have been considering ceramic brake pads for my next (first) brake service anyways. |
10-27-2023, 08:26 AM | #7 | |
![]() 217
Rep 275
2023 M3 Competition xDrive Edition 50 Jahre (Techno Violet Metallic) August 11, 2022 Production Date - SOLD
Delivery Date - October 24, 2022 2021 M340i xDrive M Performance Edition - Sold 2017 340i xDrive - Sold |
10-27-2023, 10:43 AM | #8 |
![]() ![]() 7656
Rep 7,557
I somewhat disagree with this. I think a sprayable rinse-off sealant like Gyeon WetCoat is awesome on wheels. Low effort, gives many of the benefits of a coating, will hit all surfaces. If you wash your car every month it'll last forever as you refresh it, and works well as a topper for a coating.
10-27-2023, 11:00 AM | #9 |
F15 daddymobile
![]() 2477
Rep 3,616
I have ceramic coated several wheels and at this point, i think doing anything other than the inner barrel is a waste of time. You still need to clean your wheels regularly to prevent brake dust and road debris build up. Ceramic makes it easier, but it doesn't ensure your wheels stay clean. If you are cleaning regularly, you don't need ceramic.
chris7197655.50 zero2sixtyZ1054.00 |
10-27-2023, 12:13 PM | #10 | |
![]() ![]() 7656
Rep 7,557
10-27-2023, 12:20 PM | #11 | |
F15 daddymobile
![]() 2477
Rep 3,616
10-27-2023, 01:56 PM | #12 |
![]() 409
Rep 1,023
Drives: 2007 Z4 M Coupe 2012 e93 M3
Ceramic coating (or any type of coating) will only be good with really good surface preparation. Make sure it is as clean as you can get (I even do a light polish) before applying.
Agreed with some posts above, ceramic coating won't prevent dust from sticking to the wheels but will make cleaning so much easier. |
10-27-2023, 10:24 PM | #13 | |
![]() ![]() 269
Rep 217
10-28-2023, 12:02 AM | #14 |
YNWA
![]() 1260
Rep 979
Did my new wheels last week
