10-30-2023, 10:47 PM | #1 |
Rep 93
Drives: 435i xDrive Gran Coupe
F80 Pad Fitment
Was wondering if F80 pads would fit on the front of the grey 340mm calipers. I believe the caliper is quite similar if not the same so was wondering. Been slightly disappointed with the oem pad due to lack of durability when it comes to more spirited driving so am looking for a modest upgrade. Not necessarily a fan of Hawk 5.0 either as they require slightly more pedal effort.
Thanks |
10-31-2023, 10:01 AM | #3 | |
Rep 3,958
I think the OP's in a similar boat. But i'm 99% sure of is that the rear brakes for the F80/F82 won't fit on his rear brakes because they are of a very different caliper design. The OP could be introducing some odd brake balance bias if he tried to just use the front F80/F82 brake pads. |
11-04-2023, 06:30 PM | #4 | |
Rep 93
11-05-2023, 12:35 PM | #5 | |
Rep 10,319
By mentioning durability, do you seek a pad which lasts longer? |
danb19792015.00 |
11-06-2023, 11:14 AM | #6 |
Rep 93
They don’t really hold up on more aggressive driving. They’ll usually glaze themselves after a canyon drive or start developing a permanent squeal. I’ve noticed bmw pads are really prone to squealing in general even when not driven hard. I’ve seen Hawk 5.0 pads go on a track day and still don’t develop any squealing.
11-06-2023, 03:18 PM | #7 | |
Racecar Driver
1323
Rep 2,003
Drives: BMW M4
To answer your question if they will fit and the answer is yes. When I looked up the F80 pads, it’s applicable to M sport and Non-Msport Brake calipers. |
11-06-2023, 09:26 PM | #8 | |
Rep 93
11-06-2023, 11:09 PM | #9 |
Racecar Driver
1323
Rep 2,003
Drives: BMW M4
I use Akebonos for my M4. It’s very low dusting, good enough bite, and in emergency braking it still stops. Braking distance is really based off your tires.
danb19792015.00 |
11-07-2023, 07:54 AM | #10 | |
Idiotic lifter of heavy stones...
2015
Rep 2,195
Drives: 2015 F31 325D M Sport touring
Yes they create dust; but ceramic coated wheels and a quick wash, they're clean again Re other pads; I've found Ferodo DS2500s to be very good in the past; really rated the ATE Ceramic pads on previous cars, which you can get for the larger brakes on the F3x cars via Autodoc in Germany etc Personally I wouldn't touch EBC pads; wouldn't pi$$ on them if they were on fire. Had plenty of bad experiences with them (Redstuff & Yellowstuff) and avoid them like the plague now. Know plenty of folk that have suffered similar issues (not running very well; poor bedding in, lots of squealing, lots of dust (more so the Redstuff); poor/uneven wear etc - that's using blank as well as C/J Hook & other grooved discs) Unless you're going to go hard on track; the F80 M3 pads are good also; my pal runs them in his F30 340i which has been remapped and is used on a few tracks around the UK and he's had zero issues (he does run a separate set of wheels/tyres for his track days though); so he's not too worried about dust... Other than that, no untoward noises/squeals etc
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
MysteriousGas19.00 |
11-07-2023, 10:09 AM | #11 | |
Rep 10,319
If the brake pads develop a layer of glaze after one canyon run, the heat isn't properly dissipated. The only question is why. As the temperatures increase, the friction material in brake pads transforms into dust and gas. As the temperatures still increase (heat not being dissipated), the brake pad materials becomes harder and smoother, resembling a mirror-like surface. Once that occurs, effective friction against the rotor cannot be maintained. As the friction material in brake pads transforms into dust and gas, gas has to escape. Drilled and /or slotted rotors help the gas to escape + help dissipate the heat. As the brake pad material is removed during braking, the slots act as shaving blades and help remove the first layer of the pad material which has been glazed. This allows the brakes to function consistently despite extreme temperatures. J-hook style rotors from AP Racing do this job very well. If whatever reason the heat isn't properly dissipated during braking, evaluating better rotors will be helpful. |
11-07-2023, 09:58 PM | #12 | |
Rep 93
Due to this I have been disappointed with oem pads. I've also seen multiple m3/4 from friends who do not drive their car spiritedly at all develop squeal. I must admit the OEM pads do feel best overall though from what I have experienced. Sorry I know that was a lot lol |
