11-02-2023, 07:38 PM | #1 |
Supreme Allied Commander
3886
Rep 54,500
Drives: F80 M3
Ferodo DS3.12 brake pads bmw G8x m2 m3 m4 fcp5301g fcp4381g
DS3.12
Released in 2019, the DS3.12 is the latest evolution in Ferodo’s incredible DS line. Sports cars today have more of everything: more horsepower, more sophisticated aero, higher curb weights, and stickier tires. These attributes place serious demands on a vehicle’s brake system. The Ferodo DS3.12 is the modern pad compound designed from the start to explicitly to handle those demands. Out of all the pad compounds we’ve ever tested, from all manufacturers, the DS3.12 shows the flattest torque curve across the broadest temperature range. That means that on every turn, on every track you drive, on every lap, your brake pedal is going to feel almost exactly the same, providing tremendous consistency and repeatability. The DS3.12 has a higher mu than Ferodo’s other compounds, so not as much leg pressure is required to initiate the desired response. It is also unfadable, showing no drop in performance at any temp your brakes will ever see. In dyno testing, the DS3.12 has shown superior wear rates to the other Ferodo compounds, while remaining kind to the discs. We believe the DS3.12 will become the gold standard to which other race compounds will be compared. Part #: 11 FCP5301G-N Part #: 11 FCP4381G-N Brand: Ferodo Racing Replacement pads for OEM front & rear calipers on BMW M2 (G87), M3 (G80) and M4 (G82) equipped with the standard M Compound iron discs (including Competition models). NOT FOR USE WITH CARBON CERAMIC DISCS Order here: https://hpautosport.com/product/fero...bmw-g8x-m3-m4/ |
11-24-2023, 02:07 PM | #4 |
3886
Rep 54,500
Drives: F80 M3
Pads are 10+% off, and AP BBK is up to $1000 off during November! PM for a quote!
