BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos Slime tire inflator broke on the first use
      11-09-2023, 02:25 PM   #1
spicyB48
spicyB48's Avatar
Drives: 2019 BMW 330i
I bought a Slime brand tire inflator to top up my tires, and it broke on the first use. It turns out that the internals are 100% plastic. Plastic cylinder, plastic piston, plastic gears, plastic connecting rod, even the pressure gauge mechanism is all plastic. The plastic connecting rod had snapped after the plastic piston seized up inside the plastic cylinder. Piece of junk.
WTF, Slime? I have lost all faith in the brand. I guess I shouldn't have expected too much from the company that makes TPMS-destroying sealant.
      11-09-2023, 06:14 PM   #2
Tejas1836
Tejas1836's Avatar
1198
Drives: 2023 X5MC Workmaster 75
How old was it? They probably should be replaced on an annual basis, the goop eventually thickens/hardens, BMW branded bottle will do the same eventually. It should have an expiration date on it
Two is One and One is None
      11-09-2023, 06:35 PM   #3
spicyB48
spicyB48's Avatar
I wasn't using the goop, I was just using the Slime brand compressor to top up my tires (they were a few psi low).
Tejas18361197.50
      11-09-2023, 07:39 PM   #4
Donatello.
How's My Driving?
Donatello.'s Avatar
1290
Drives: Hellcat & Miata
I've used a can of the stuff before & it worked well. Never bought their inflation pump thing. I carry a separate inflation pump in every car.
Maybe you just had a bad apple?
2018 Charger Hellcat
2019 Miata 30th Anniversary
2021 CX-5 Signature
2009 Mazda6
      11-09-2023, 07:51 PM   #5
No one
Drives: F21 118i
Smile
Originally Posted by Bimmerito View Post
I bought a Slime brand tire inflator to top up my tires. It turns out that the internals are 100% plastic. Plastic cylinder, plastic piston, plastic gears, plastic connecting rod, even the pressure gauge mechanism is all plastic.
Sara, if you don't have it yet, you should buy it!
      11-09-2023, 09:25 PM   #6
spicyB48
spicyB48's Avatar
I have never used their sealant, but I don't think I got a bad apple. Seriously, just look at the build quality. It's all plastic.
      11-10-2023, 10:39 AM   #7
Theodore2
Drives: E92 M3
If you are willing to buy once and cry once, I've had this model here in the trunk of my car for 5 years using it every few months and it has been great.
Torgus3806.00
      11-10-2023, 11:23 AM   #8
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
Drives: 11' 335is DCT
Yeah unfortunely I believe all these cheap-ish tire inflators these days are all made out of plastic. That said maybe you got a bad one to for it to break so quickly. I have some cheap ones that I've used multiple times.
You need to shell out a bit more for the all metal ones like the one above or those labelled "heavy duty".
      11-10-2023, 12:23 PM   #9
spicyB48
spicyB48's Avatar
I saw Viair also makes a smaller one for $60, I might pick one up.
///M - the most expensive letter of the alphabet
      11-10-2023, 12:24 PM   #10
spicyB48
spicyB48's Avatar
Those cheapish inflators used to have a metal cylinder and gears, at least a year ago they did. Now they are all plastic, I think there is one central company in China making all of them.
