11-14-2023, 11:45 AM | #1 |
Rep 43
2012 F30 strut mount and bolt
My car's production year is 2012. The strut mount has 3 holes and uses M8.
Based on realoem the mount part number is 31306855817/31306855818 and the bolt number is 31306862826. But unfortunately they are all discontinued and nowhere to buy. Anybody knows if I can use the newer part 31306880438 with 3 M10 bolts instead? Thx! The left is the M10 31306863134 bolt and the right is mine. |
11-15-2023, 03:23 AM | #2 | |
Idiotic lifter of heavy stones...
2015
Rep 2,195
Drives: 2015 F31 325D M Sport touring
https://www.ebay.co.uk/itm/175590071...Bk9SR-jN06T6Yg Replaces the one you've asked about
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
11-15-2023, 07:26 AM | #3 | |
Rep 8,523
I found this : https://www.fcpeuro.com/products/bmw...mw-31306862826 Worth checking whether it's compatible.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
11-15-2023, 06:24 PM | #4 | |
Rep 43
I understand the M10 bolt will not fit my current strut mount which takes M8 bolts. My question is if I can use the M10 bolt with a new strut mount which takes M10 bolts. I want to replace the strut mount also and it's hard to buy a strut mount which takes M8 bolts now. |
wishbone194.00 |
11-20-2023, 11:17 AM | #5 | |
///M
194
Rep 706
Drives: '18 F80 M3 ZCP, '14 F30 328i
When I ordered the strut mounts from FCP Euro (PN#31306880438) they shipped me the hex bolts with washers (PN# 31306863134). The kit offers the same bolts & washers: https://www.fcpeuro.com/products/bmw...le-31306880438 IIRC my stock hex bolts + washers are taller (see picture): I would imagine the newer PN#31306880438 should fit into your strut tower however, the m8 bolt holes would presumably be smaller, right? Cant' tell if the below is pure shipping dimension or not, i can measure my Meyle's for you (PN# ...38) Additionally, per (https://www.schmiedmann.com/en/produ...=31306855817B1) your specs are: 28x10x17 cm The same appears to be true on the PN# ...38 28x10x17 cm (https://www.schmiedmann.com/en/produ...=31306880438B1)
F80 ///M3 '18 S55/ ZCP / executive / 6MT / eventuri CF CAI V2/ CSF TMIC
F30 328i '14 N20 / dinan sport kit / premium pkg / 6MT / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CF CAI Last edited by wishbone; 11-20-2023 at 11:54 AM.. |
12-02-2023, 02:19 PM | #7 |
Rep 12
There are 3 top mounts for our cars:
3 x M8 (pre-mid 2014) 3 x M10 (mid-2014-2015) 5 (and 6) x M8 (2016-) BMW kept using the previous model until they were gone, so there is no set date to look up to determine which you have. You have to lift the hood and check it out. The M10 have a thicker washer FWIW |
12-02-2023, 07:04 PM | #8 | |
Rep 43
12-04-2023, 07:37 AM | #9 | |
Rep 12
The holes themselves line up perfectly. |
12-04-2023, 10:17 AM | #10 | |
///M
194
Rep 706
F30 328i '14 N20 / dinan sport kit / premium pkg / 6MT / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CF CAI |
12-10-2023, 05:41 PM | #11 | |
Rep 43
I measured the size of the hole and it's just slightly smaller than 10mm ;( Guess have to trim the hold a bit if I have to replace given there is no where to find the part. Sad to receive little love as early year owner. |
12-12-2023, 09:37 AM | #12 | |
Rep 12
giraffewt15.00 |
