11-19-2023, 07:21 AM | #1 |
Rep 142
Anybody install an aftermarket stereo system in their X7?
My cars always go through their right of passage with an aftermarket stereo (done this since I was in high school ). Has anybody else had an install done?
I haven’t done anything to my X7 yet (HK system), I’ll probably have my shop move over what I can from my X3 since I’m in love with the Morels - they sound absolutely astonishing:
I am wondering a couple things though. 1. Does the HK have center speakers? In my X3 they did, but we disconnected them in lieu of the L/R upgrades optimized for the driver with the DSP. Given I want all passengers to enjoy this time around, I may opt for a center upgrade too. 2. I heard the HK (or was it B&W) has 8” subs under the seat. Has anybody upgrade these to mid-range woofers? I won’t need additonal subs with the JLs. 3. Looks like there’s plenty of space in the spare tire well for a stealth box, but given it’s bigger than the X3 well, I may see if the shop can fit three 13” JLs in there. Anybody have a box in their car? |
11-19-2023, 07:41 AM | #2 | |
Rep 3,607
some members on the g05 forum have found that the car now does an impedence check on the front speakers. if it doesnt match what its expecting, it disables drive assist pro. likely because the front speakers are used to play audio alerts for the dap system. and they're locking down everything these days. it was a 2024 X5 but i suspect bmw has done it on the LCI X7 as well https://g05.bimmerpost.com/forums/sh....php?t=2039216
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC Last edited by Orient330iNYC; 11-19-2023 at 07:58 AM.. |
11-19-2023, 08:50 AM | #4 |
Rep 537
I think the more these cars get into automation and electronics, the less we will be able to control what we can do in the cars. I am still venting that my car is spending the weekend at the dealer because it went to get a software update, it did not install correctly for whatever reason, and the entire car became useless. Not even able to start the car. I think the automation and electronics are great to the point it adds safety and lots of convenience stuff into the cars but at the same time it adds way too much complexity. The fact that you cannot replace your speakers is absolutely mind blowing. I miss the cars when there was a key that you had to turn to get it started.
11-19-2023, 08:56 AM | #5 | |
Rep 142
UPDATE: read through that thread. Seriously concerning :/ I wonder if my shop would even know if DAP gets disabled. I assume BMW would be the folks to contact to confirm before I get any work done. Last edited by tinfoiltuna; 11-19-2023 at 09:04 AM.. |
11-19-2023, 09:12 AM | #6 | |
Rep 3,607
easy check, unplug one of the speakers, center channel is easiest to get to. if DAP gets disabled, well, you know its checking. you wont be able to turn on lane assist or any of the other functions if it is disabled and it will throw a drive assist restricted error.
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
