11-19-2023, 11:28 AM | #1 |
Rep 29
End of this summer I felt some vibrations when braking and the BMW-shop took it in and found that the right rear brake disc needs to be changed. Car is one year old. No warranty covers it and both rear disc + pads needs to be changed to approx 1500 USD. No goodwill either😭
I went to one track day and the vibrations did not occur after that day, it came 2-3 months later. Otherwise ”normal” driving. Anyone with simular experience? Is this was to expect, new pair of discs every year? |
11-19-2023, 12:34 PM | #2 |
Rep 3,276
Drives: E46 M3 Coupe/G80 M3CX
Brakes. They are consumables, especially on this car. Swap it out and get on with your life.
shwayne557.00 BackOnBlack792.00 |
11-28-2023, 04:12 PM | #3 | |
Rep 413
Drives: BMW F30 335i xdrive
Btw: they should not only change rotors but also pads, and you will be total over 3k or even 4k. They charged bmw 2.5k just for my back rotors and pads but warranty covered it; as my pads were wear out in a way the sensor this not triger the light and I did scrape the rotors with wear our pad. They did not blame me and warranty covered it. Not even maintanance plan. PS. I think your dealer is not supportive to ypir case. This is M car not regular 3 serious. When I went with brakes issue all were happy that car is driven like M car ! Hard !!! |
eugenebmw1597.00 |
11-28-2023, 04:40 PM | #4 |
Rep 515
Depend on what driving skill you drive on track as well as the track condition. If you are pushing every corner very hard with DSC fully on. It burn a lot on the rear brake.
If you didn't know, a BMW replacement battery in the G9X is about $1500+. On top you have to pay for reprograming. If you haven't got yourself a battery charger, it is time to invest into one lol. |
11-28-2023, 04:45 PM | #5 | |
Rep 515
Bostro532.50 Forzanerazzurri6922.50 |
11-28-2023, 04:47 PM | #6 | |
Rep 413
Dang… battery… have a battery charger… will start monitoring it as i already had one message from my app about low battery voltage. :-( |
eugenebmw1597.00 |
11-30-2023, 05:52 PM | #7 | |
Rep 515
Bostro532.50 |
11-30-2023, 09:50 PM | #8 | |
1967
Rep 1,927
Drives: E92 M3
Dealerships will always push for a rotor replacement with brake pads to avoid people returning because "it still squeals/shakes".
11-30-2023, 10:12 PM | #9 | |
Rep 413
This is true in the way that BMW has raised the bar for M cars when it comes to rotors thickness at the time of pads replacements. My foreman told me on my previous generation M4 in most cases you could have two sets of pads for one set of rotors. For new Gxx generation they raised the limit when you need to exchange the rotors and this comes from BMW, not delearship which also said it is non-sense but … this is what it is. If they would change only pads delership would have serious liability issues due to BMW policy violation. As I wrote above, experienced this but in my case bmw paid for all rotors, so for me all was to my advantage. Our cars are not cheap to drive soft or hard :-D |
12-01-2023, 11:57 AM | #10 | |
Rep 515
Bostro532.50 |
12-04-2023, 02:29 PM | #12 |
Rep 29
Thanks for all input😊🙏🏼
The dealer did show me a video the mecanic had made of the disc, it looks warped. The price 1500 USD (approx, I live in Sweden) is including both discs and pads. I did about 40 minutes total track driving with full DSC on, maybe that did something. However now the car is in winter hibination. In the meantime I will consider if I will change the rears for 1500 or if I will go for the maintance plan for 3500. I guess If I dont go for the plan, another couple of discs will fail and if I go with the plan nothing will needed to be changed 😁 |
