11-23-2023, 02:28 AM | #1 |
Rep 72
Mirror with a garage door opener
As the option isn't available in the g87, has someone tried retrofitting this? Is it complicated?
https://www.baum-bmwshop24.de/bmw-in...RoCDsMQAvD_BwE |
11-23-2023, 10:07 AM | #3 | |
Car Geek
3708
Rep 3,621
11-23-2023, 11:09 AM | #4 |
Rep 962
Drives: G87 M2, G20 330d, Brabus Smart
Realized I didn't have it in my build when I picked up the car. Asked my BMW Rep and he told me it's not available for the M2 in Germany. So weird its standard in the US.
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp) |
11-23-2023, 11:29 AM | #6 |
Rep 3,026
Drives: A Family Sedan
You could try to retrofit it yourself, but I'm not sure our cars without the Homelink will have all the needed wires to make it work:
https://www.schmiedmann.com/en/produ...1-16-2-472-237 |
11-23-2023, 12:04 PM | #7 |
Car Geek
3708
Rep 3,621
With the electrochromic feature as well as the garage door opener, it should be this mirror: https://www.schmiedmann.com/en/cata-ol?q=51169476752#
M2siast5951.00 |
11-23-2023, 12:19 PM | #8 | |
Rep 3,026
11-23-2023, 12:28 PM | #9 |
Car Geek
3708
Rep 3,621
One thing to be aware of when replacing the mirror, though, is that things such as auto high-beam and driver assistance features on a specific car can change the specific mirror required for compatibility of all the features.
11-27-2023, 03:14 AM | #10 |
Rep 72
After a lot of research, seems there are major compatibility issues between different garage doors and homelink... So even if the mirror itself can be retrofitted it won't work with my garage door because of some rolling code encryption BS
I assumed a remote is a remote and it works with every system... Nope. |
11-27-2023, 06:51 AM | #11 | |
Rep 72
https://www.wired.com/2015/06/hacked...doors-seconds/ |
sclouzon16.50 |
11-27-2023, 07:36 AM | #12 | |
Rep 3,026
You will need access to the garage door opener control box, to push the “learn” button while you setup your control. So if you live in a house and own the garage door opener, you can do it. If you live in a building, you likely will not be able to do it. |
11-27-2023, 08:04 AM | #13 |
Rep 77
I won't say "I haven't had any problems", but was able to get my homelink mirrors (on prior car and the new BMW) to work with one of the latest "rolling code" garage door openers.
You need to be very careful and methodical in following the instructions on both your garage door opener and the mirror setup in the owner's manual. Everything has to be in the proper mode and you need the proper "feedback" (mostly blinking lights) from opener and mirror. One thing that was not clear from the instructions in the owners manual was that the car itself needs to be in the correct "on not started" state for all of the mirror stuff to work as expected. I have an older truck that has a homelink system that will NOT work with the newer openers. So, they do eventually become obsolete. They do make repeaters that will talk to the new opener on one side and the old homelink on the other. Last edited by Smilodon; 11-27-2023 at 08:12 AM.. |
11-27-2023, 08:45 AM | #14 |
Rep 268
As an alternative, you can get a wifi controlled switch and pair it to your Amazon Alexa account. I have that on one of my garage doors so when I am driving up to the house I say, "Alexa, activate blah blah blah" and it is the equivalent of pushing the garage door button. I wish that I could say "open the garage" and "close the garage" and I could only open if the door was closed but that requires inputs which Amazon does not support.
Admittingly, there are some security concerns because theoretically someone could stand outside of my house and yell the activation words and the garage door would open but they would have to yell pretty loud and know the activation words that I selected. It also won't work if the wifi in your house is down and sometimes the Alexa app on your car is glitchy. And of course, I have no idea what Amazon Alexa features are available in your country but perhaps it is an option.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
11-27-2023, 10:50 AM | #15 |
Car Geek
3708
Rep 3,621
We have a Chamberlain / Liftmaster rolling code garage door opener that is fairly recent and has features such as app control via Internet connectivity, autoclose, wireless keypad, etc.
The G87 homelink mirror remote works fine with it. |
11-27-2023, 11:33 AM | #16 |
Rep 72
In my case it’s a building gate, if internet is to be believed it might be the only system that doesn’t work with any universal opener and homelink. Literally the only way is with an original remote. I also looked into one of those solutions that plugs into a cigarette lighter, but no luck..
11-27-2023, 02:41 PM | #17 | |
Rep 397
you can check with choosing your remote or you know wich garagedoorsystem is used.. |
11-27-2023, 04:14 PM | #18 |
Rep 3,026
I maintain your issue might not be the home link, but your lack of access to the garage door opener.
11-28-2023, 05:42 AM | #19 |
Rep 72
11-28-2023, 07:30 AM | #20 |
Rep 91
Pretty sure it’s the same mirror found in the X3, X4, X5 M3, you could probably find a used one on eBay and fit it. My guess would be it takes power from the same harness that already powers the mirror. In my Mini, and a few other BMW’s I didn’t have to retrofit any wiring. Just plug and play.
