11-23-2023, 05:04 PM | #1 |
Rep 846
Drives: 2009 E93 M3
Garage List 2008 E90 M3 [0.00]
1995 BMW M3 [0.00] 2004 BMW M3 [0.00] 2011 BMW 335xi [0.00] 2011 BMW 335is [0.00] 2009 BMW M3 [0.00] |
Ohlins R&T (x-drive)
Anyone running this kit on their cars?
I ran it on my e92 - and it went quite a bit low - but was wondering if anyone was having issues with running the suspension on max low |
11-24-2023, 07:42 AM | #2 |
BimmerPost Supporting Vendor
24503
Rep 191,503
I don't know about running it on max low, but Ohline R&T is one of the best and most reliable kits on the market. We rarely see any issues with them.
11-30-2023, 12:09 PM | #3 | |
3893
Rep 54,605
Drives: F80 M3
What are your concerns? |
11-30-2023, 12:50 PM | #4 |
8312
Rep 18,880
Probably one of the best performing street suspensions on the market today when properly set up. How did you like it on your E92 M3?
11-30-2023, 12:53 PM | #5 | ||
Rep 846
Drives: 2009 E93 M3
to go far lower than the 25mm advertised. Quote:
going to figure out what is the true maximum drop of these coilovers |
tom @ eas8311.50 |
11-30-2023, 01:01 PM | #6 | |
8312
Rep 18,880
Get some miles on the new setup and see what you think. If you want to go lower, we can provide some options. Looking forward to your review.
11-30-2023, 01:04 PM | #7 |
Rep 846
Drives: 2009 E93 M3
Thanks Tom! will update the thread. please send kevin my regards if you see him!
tom @ eas8311.50 |
11-30-2023, 01:20 PM | #8 | |
3893
Rep 54,605
Drives: F80 M3
You can also try negative preload, but that that is not recommended. Another option is to do negative preload with a helper spring. |
HolyChitMeng1300.00 |
11-30-2023, 01:29 PM | #9 |
2955
Rep 21,785
Cant wait to see them installed! Be sure to post up some pictures once everything is setup.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
12-05-2023, 12:15 AM | #10 |
Rep 846
Drives: 2009 E93 M3
update: car did not go lower than the KW H.A.S kit. this is as low as it can go.
I'd be lying if I said I wasn't bummed. going to contact others for a solution hopefully. |
12-05-2023, 10:55 AM | #11 |
24503
Rep 191,503
Let us know how it goes
12-06-2023, 02:03 PM | #12 |
Rep 846
Drives: 2009 E93 M3
12-09-2023, 11:12 PM | #13 |
Rep 165
DrRay81 has them. Had some issues with the height but he worked it out with pre-load. Spent plenty of time back and forth with Ohlin and the installer who we all use. He’s got a whole thread on it.
https://g80.bimmerpost.com/forums/sh....php?t=2057944
Perf: FEMTO/BM3 Stage 1 OTS, AA Signature EL Midpipe
Susp: KW V3, Fall Line Monoballs, 18/15MM Future Classic Stop: iSweep2000 Cosmetic: Full Body PPF, RSC Front Splittler, AUTOTECKNIC V1 Front Grill, M-Perf CF Side Vents, RSC CF Side Skirts, RW Carbon Rear Winglets, Painted Black Exhaust, Amber Deletes, |
12-11-2023, 08:35 PM | #14 | |
3893
Rep 54,605
Drives: F80 M3
If you are concerned about negative preload, feel free to reach out for a pair of the Ohlins helper springs. |
12-11-2023, 08:48 PM | #15 |
Rep 846
Drives: 2009 E93 M3
12-11-2023, 09:59 PM | #16 |
3893
Rep 54,605
Drives: F80 M3
12-14-2023, 12:49 PM | #17 |
Rep 7
The camber plates Ray is using from Vorshlag have the same spring stack height as OE but has a TALLER strut stack height from OE. This allows the top of the strut ("pin") to fit below where the camber plate is bolted to the body to allow the "pin" of the strut to fit UNDER the body for additional camber adjustability.
This poses a problem as this added strut height relative to OE can have a number of less preferred results. First, it could reduce bump travel if you cannot adjust how far the strut casing can be adjusted into the suspension upright (like the R&T's unique feature owners like so much). The problem with xDrive cars is you can simply adjust the strut extremely low relative to the upright because the axle boot is there. This is the situation Ray is in with the Vorshlag mounts and is why owners retaining the OE mounts do not have a similar issue. Millway reports specifically having the same stack height as OE for the spring AND the shock. This is important as manufacturers like Öhlins develop their street-oriented suspension systems retaining the OE top mount and it's geometry. Hope this helps clarify the circumstances. |
somer973.50 |
