11-23-2023, 08:48 PM | #1 |
Rep 138
Ground Clearance of the G60? 6.5 inches?
BMW stopped publishing ground clearance unlike other brands several years ago. If you google G60 Ground clearance I was seeing 6.5 inches. That is higher than the outgoing model at 5.5 inches. Is It possible that the new car has an extra inch under the chassis? I know you ride up higher with the Electric platform but was hoping it might actually have better ground clearance. Any ideas? Why does BMW not publish this?
11-24-2023, 03:01 AM | #2 |
Rep 665
The ground clearance on the G60 is a maximum of 154 mm = 6". On the i5 a little less = 146 mm.
11-24-2023, 03:21 AM | #3 |
Rep 138
So an X Drive 530 would be the maximum of 6.0 right? Non-M Sport? Where did you get that info from? Seems a bit higher than other BMW cars that are around 5.5. Is the higher clearance due to the platform being gas or electric?
11-24-2023, 03:49 AM | #4 |
Rep 665
BMW does not provide any information on the HP because the ground clearance is approximately 130 to 154 mm depending on the model and equipment.
But the largest German automobile club has all the data ready. M60 = 136 mm e40 = 146 mm 520d = 154 mm 530/540 = Not in GER. |
11-24-2023, 10:26 AM | #5 |
Rep 5,125
What’s reason for asking, is for water depth?
I know driving through any water is potentially a very expensive mistake but with the battery at the bottom of the chassis, I guess this is something all you BEV drivers need to be aware of and adhere to. Thought of driving through say 8 inches of water is fearful |
11-24-2023, 11:27 AM | #6 | |
Rep 833
