BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) Coding my U11 M35i
      11-25-2023, 05:26 PM   #1
ajsti24
ajsti24's Avatar
33
Drives: U11, S209, 8Y-S3
Coding my U11 M35i
Attempted to code my M35i using OBDLink-CX...did not recognize my car. Instead used my OBDEleven and here is what's available..not too much. I just coded the sound signal to original BMW, I did not like the BMW i sound set.
      11-26-2023, 03:17 AM   #2
MontyB1
Drives: BMW X3
Very little you can do with the U11 X1 family, BMW controls config on its servers now pretty much. All the normal coding options don’t work and they have said it’s unlikely it will every be possible like the previous models.
      11-28-2023, 06:25 PM   #3
U11sirgawain
U11sirgawain's Avatar
Spain
100
Drives: bmw x1 3.0e u11
If you select BMW U11 on their page.....they show much more settings than those 2.
Do you have id8 or id9?
If all showed settings are available, I might buy adaptor and one click apps for my 30e
If only 2, no way.
Besides one click apps for coding, What info can you get from your U11 to your mobile?
Ex320i, ex325ix, ex850i, ex530dTouring
      11-28-2023, 06:50 PM   #4
ajsti24
ajsti24's Avatar
33
If only 2, no way.
Unfortunately only 2 coding currently available for the U11(shown above attachment), i believe i have the id9.
      11-28-2023, 06:59 PM   #5
U11sirgawain
Spain
100
Unfortunately only 2 coding currently available for the U11, i believe i have the id9.
According to their website, they have 21 coding for U11. Hope id8 (my car 30e) can use then all.
I have just ordered through Amazon, so if they don't work....I ll return the dongle!
      11-29-2023, 05:57 AM   #6
Kosymodo
Kosymodo's Avatar
Drives: iX1 xDrive30 M Sport
Just checked their website and it seems you're correct. Therefore, it'll be interesting to see what your experience is when you receive your device! Don't forget to update this thread
      11-29-2023, 06:03 AM   #7
FlashMonkey929
I Shoot People For Money
FlashMonkey929's Avatar
1222
Drives: 2023 Portimao MSport X1
2003 BMW 330i ZHP  [0.00]
2023 BMW X1  [10.00]
I'm interested to see what happens after you bring it into the dealer. Supposedly, with ID8 and ID9, if you make any coding changes that weren't authorized by BMW, they can see it and potentially flag your car in the system as soon as your car is hooked up for diagnostics. This is done supposedly through a checksum verification as well, so even if you code it back to stock it knows how many times a module has been written to, and if it doesn't match with the number of times BMW has logged it can be trouble.
Again, not saying it's true, but from things I've been reading while researching coding for ID8. I'm actually hoping for it not to be true so I can code my own car eventually.
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold-
2020 430i Estoril Coupe MSport -returned-
2023 X1 Portimao, Msport, Premium
2003 330i Imola Red ZHP 6 Speed
      11-29-2023, 09:54 AM   #8
SpaceSilver.X1
world's slowest BMW driver
1554
Drives: U11, G60, W211, AZ20
BMW dealer must have tools that allow them to do a lot of things in the car's computer.
When I paid to have the oil changed at 1000 miles for peace of mind, I specifically told the service advisor and the tech NOT to reset the oil counter(or whatever they called it). The service advisor even had it printed on the invoice. The reason was that I didn't want the the car to wait another 10,000 miles before alerting me to another oil change(which would be free under BMW's free 3-year maintenance)
However, when I picked it up, sure enough, the tech had forgotten about it and the counter was reset. I went back a few days later and asked the tech about it. He apologized and said that he had too many cars that day. He drove it into the service dept and hooked it up to the biggest diagnostics computer I had ever seen(about the size of a portable air conditioner on wheels. After 10 minutes, he brought the car out again and the oil change interval was reduced by about 1000 miles.(or back to what it should have been) He said he was able to "cancel" the reset that he did, so the car "forgot" about that oil change.
      11-29-2023, 11:13 AM   #9
U11sirgawain
Spain
100
OBD11 states on their webpage that they are VAG and BMW certified. Whatever that means!
      11-29-2023, 03:51 PM   #10
FlashMonkey929
1222
2023 BMW X1  [10.00]
I hope they’re right, but I suspect it just means “compatible” and not actually licensed by BMW.
      11-29-2023, 03:53 PM   #11
FlashMonkey929
1222
2023 BMW X1  [10.00]
It’s possible to adjust the service interval to a specific mileage or date. You used to be able to reset the interval using a combination of buttons on older BMWs, not sure if you can do it on the U11’s
      04-15-2024, 10:31 PM   #12
ajsti24
ajsti24's Avatar
33
After my 11/2023.73 software update, only one item was added to my obdeleven app, Active sound deactivation
      04-17-2024, 10:34 AM   #13
Timchi
Drives: 2024 X1 M35i
what do these settings do? - anything to make the exhaust sound better?
      04-17-2024, 10:50 AM   #14
MontyB1
Drives: BMW X3
All those settings turn sound off. So external warning required under EU law for example you can turn off, fine until you hit someone and they find it was off, good luck then.
Internal sound is the augmented exhaust or sound on PHEV and switching it off, not changing or enhancing its a deactivate.
      04-17-2024, 03:46 PM   #15
Timchi
That’s no fun
