12-04-2023, 04:21 PM | #1 |
Rep 14
Coding Fault
Hi. I replaced my EPS with an used one and I tried to code it with E-Sys but that failed and now the EPS is solid as a rock. It says that there was an error on the Tal Execution and it gives Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: EPS_30_ETHERNET. Sugestions?
12-05-2023, 07:39 AM | #3 |
Rep 41,221
Drives: 2018 Alpina B6 650ix GC
You need to flash EPS, and if your EPS has Servotronic FSC Code, you need to Import your original FSC Code into Donor EPS, and that is only possible if the Donor EPS has no FSC Code already in it, or has an older one than yours.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
