12-11-2023, 03:33 PM | #1 |
Rep 107
oil drain plug was undertorqued at factory
I just did my first oil change at 1372 mi and the oil drain plug came loose with like zero pressure on the wrench! Seriously, I just started to apply pressure with the socket wrench and it started to turn! No, I am not a body builder or strong guy. Anyone else note this?
I'm going to put a separate post re what I like to use for the torque wrench. 25 nm = 18 ft-lbs = 216 in-lbs is too little to even show on most 100 ft-lb torque wrenches and my inch-lbs wrench only goes to 200. |
12-12-2023, 05:02 AM | #3 | |
Rep 1,193
FWIW just to show you there is some variation in drain plug tightening torque, from the engine oil change section of my Porsche 996 Turbo: Tighten the drain plug on the crankcase to 70 Nm (52 ftlb.) those on the oil container [tank] to 60 Nm (44 ftlb.), and the drain plugs on the turbocharger to 30 Nm (22 ftlb.). The above is not to suggest you should use any of those values but use what BMW calls for. |
12-12-2023, 01:46 PM | #4 | |
Rep 107
12-13-2023, 12:09 PM | #5 |
Rep 142
This is from a BMW service manual. May or may not be for a B58, but 25Nm is the most common value I saw anyway.
In most cases matches the torque for the plastic oil filter housing. They make it easy to remember
'17 - Boxster 6SP/SSK/Brombacher
'23 - Polestar 2 '23 - M240 xDrive (winter car) |
