BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) Creaking driver's window headliner?
      12-11-2023, 09:04 PM   #1
jihong
Drives: 2015 328xi
On random occasions, the plastic trim on the inside of the driver's side window creaks when going over bumpy roads (not potholes and uneven terrain, but more poorly paved streets). It's not the window or the rubbering because it doesn't go away when I shove something there or press against the glass or rubber, but the more inner plastic trim. It only goes away temporarily if I press up really hard on the plastic trim.
Anyone else experience this or have a solution?
      12-12-2023, 02:12 AM   #2
sclord
Drives: BMW X1 U11
Happens to me as well, but didn't bother with it yet... I would also like to see if anyone has come up with a solution.
      12-12-2023, 10:45 PM   #3
SpaceSilver.X1
world's slowest BMW driver
1554
Drives: U11, G60, W211, AZ20
not if this is the one you're referring to...
but on my X1, the black plastic strip(see pic below, pointed by the red arrow) makes creaking sound whenever the weather is very hot or very cold....
      01-04-2024, 07:47 AM   #4
sclord
Drives: BMW X1 U11
Hello and happy new year everyone! I finally found some time to deal with it and judging by the results I successfully pinpointed what was causing the squeakiness.
I applied some WD-40 Specialist Silicon spray on a small painting brush and only applied once on the connection between the rubber and the door pillar as shown with green color in the next photo.
I've been trying to hear squeaks all week, but all I heard was silence! Hope it helps!
      01-04-2024, 09:22 AM   #5
BMWZ4
BMWZ4's Avatar
1926
Drives: '23 X1/'23 Allroad Progressiv
Alternatively, your dealer can investigate/fix for you if you're under warranty, which I expect you are
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
      01-05-2024, 01:58 AM   #6
sclord
Drives: BMW X1 U11
...that is if you trust them and they won't do it as a choire because it's 'a minor thing and not really a problem'
      01-05-2024, 07:01 AM   #7
abirmaher
abirmaher's Avatar
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
  [0.00]
2018 BMW M2  [10.00]
I’ve been hearing something almost constantly since delivery. Super annoying being right in my ear. Thanks for the info! Going to try your fix.
Can you mark on a photo where you applied the WD40? Not sure I know exactly where you mean.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      01-05-2024, 09:28 AM   #8
sclord
Drives: BMW X1 U11
I have already marked in with a bright green line on top of the front door pillar.
Edit: adding a better angle to make it clearer:
timesone241.00
      01-05-2024, 10:03 AM   #9
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
Sorry I missed it. Thanks, going to give this a try.
Follow my builds:
