12-23-2023, 07:31 AM | #1 |
M2 comp
62
Rep 75
How 2 remove 2023 large dash
If you need to remove the 2023 onwards large dash display then all you need to do is:
Remove plastic surround from back support (centre of dashboard), remove Tx20 screw Remove plastic trim from top of steering wheel surround - it just unclips Remove the two Tx20 screws from the dash display mounting lugs Lift up entire dash display, there are a couple of electrical plugs That's it. I was swapping my G42 black dash trim for a G87 carbon item. |
