F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > Coolant issue?
proTUNING Freaks
      12-24-2023, 09:27 PM   #1
Bobaloo2
Drives: 2015 435i xDrive Coupe
Coolant issue?
Hello Bimmer dudes!- need your expert advice. Please read the following;
Re: 2015 435i xDrive Coupe
-A week ago I had to replace the upper expansion tank vent hose (did so with no problem).
-Added coolant/distilled water 50/50
-No issues until today.
-Today my check engine light came on. Code reader said it was a coolant issue.
-Drove it a while and temp gauge stayed pegged at lowest temp (150 degrees).
Any ideas what's going on?
      12-24-2023, 09:30 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Did you use a vacuum filler device?
      12-24-2023, 10:19 PM   #3
Bobaloo2
Yikes...I did not. All my research didnt mention it so I missed it. What should I do going forward?
      12-25-2023, 08:30 AM   #4
Billfitz
Billfitz's Avatar
https://www.google.com/search?client...+vacuum+filler
      01-10-2024, 11:06 AM   #5
rlesko
Drives: F30 335i
2012 335i  [0.00]
Did you run the coolant bleeding procedure to purge air pockets in the system?
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo
f30post
