BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) 2024 - Auto Start stop disable?
      12-26-2023, 02:15 PM   #1
kreizyidiot
Drives: '18 X1 sDrive28i
Hey guys
There's been many post about not being able to disable auto start/stop in the 2023 version, with work arounds to change to sport mode and shortcut programs via OBD.
I have read on somewhere on line that the 2024 regular and M version does have this on their manual and option console.
Can someone confirm?
Thanks!
      12-26-2023, 02:23 PM   #2
FZI89
FZI89's Avatar
Austria
685
Drives: BMW iX1, U11
Originally Posted by kreizyidiot View Post
Hey guys
Thanks!
All versions have the option to disable auto start/stop. The problem is that this only stays disabled per engine start. So, everytime you turn the engine off, the auto start/stip gets re-enabled. Keeping it disabled permanently is the problem
timesone241.00
abirmaher892.50
      12-26-2023, 05:14 PM   #3
SpaceSilver.X1
world's slowest BMW driver
1554
Drives: U11, G60, W211, AZ20
all versions?
wait a minute... are you saying that the iX1 also have this?
      12-26-2023, 05:24 PM   #4
FZI89
FZI89's Avatar
Austria
685
Originally Posted by SpaceSilver.X1 View Post
all versions?
All ICE and PHEV models* 🤣
Luckily the iX1 does NOT have this problem!
      12-26-2023, 05:31 PM   #5
SpaceSilver.X1
1554
All ICE and PHEV models* ��
After 8 months, I have already trained myself to swipe down for the shortcut and hit two buttons to disable it whenever I start the engine. I don't even have to think about it 90% of the time.
FZI89684.50
RNorb342.00
      12-26-2023, 06:55 PM   #6
08-335xi
Drives: 08-335xi sedan
I have tried many options to disable the ASS on our M35i. So far all of them reset themselves when you restart the vehicle and are not very simple. The options I found and caveats with each are:
1. Create a shortcut to the ASS disable. This requires a swipe down, press of the shortcut to get to the menu and then pressing the disable ASS once button. This option works the best in my opinion as it does not change any other function, but takes too long to get to it especially considering you have to get ID9 to startup and to get past the disclaimer message.
2. Switch to sport mode. This requires two selections (mode button on center console and sport setting on the touch screen. This changes all functions of the vehicle to sport mode. (Throttle mapping, shifting parameters, gauge displays, etc).
3. Pull back on the shift lever an additional time to toggle the drivetrain between sport and comfort. This seems to put just the drivetrain into sport mode and not the other features of sport mode. This can be toggled between regular “D” and “S1,2,etc.) and it’s pretty quick. The challenge is always remembering to pull the lever before you need to get moving quickly. This is fastest method I have found with the negatives of finding myself switching between D and S frequently.
I thought I might have a winner by customizing sport mode settings to have the powertrain in comfort mode. My hope was that I could shift into sport mode by switching the shift lever to defeat ASS (one action), but get the comfort shifting and throttle mapping. What I learned is that pulling the lever only appears to adjust the powertrain into sport mode. It doesn’t affect other parameters regardless of how you have customized sport mode. I also learned that when you customize sport mode to have the drivetrain in comfort, the ASS comes back on. I have yet to find a way to not have ASS enabled and the drivetrain be in comfort settings outside of option 1 above.
If anyone else has found another work around please share your findings.
      12-26-2023, 07:06 PM   #7
SpaceSilver.X1
1554
probably never... (based on all the threads I've read this year and personal experimentation)
the only other possibilities are:
(1) BMW adds this as a paid feature in the Connected Store and charges $5 to $10 a month
(2) coding becomes possible.(also extremely unlikely)
(3) acquire a trunk monkey and train him to disable ASS whenever I drive
(4) keep AC at maximum cold all the time, which seemed to have worked when it was warm... as the car kept the engine running continuously
      12-27-2023, 02:53 AM   #8
FlashMonkey929
I Shoot People For Money
FlashMonkey929's Avatar
1218
Drives: 2023 Portimao MSport X1
2003 BMW 330i ZHP  [0.00]
2023 BMW X1  [10.00]
Pulling back on the lever doesn't engage sport mode, merely enables sport shift. There's a slight difference between the throttle mapping between the actual Sport Mode and just pulling the lever back and I believe it also holds the gears longer in one of them, I'll have to test it again when I have time. As far as I know, there's no other workaround that I've been able to discover, but flipping the lever between D/S has become second nature to me by now.
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold-
2020 430i Estoril Coupe MSport -returned-
2023 X1 Portimao, Msport, Premium
2003 330i Imola Red ZHP 6 Speed
Spdrush10.50
      12-28-2023, 03:44 AM   #9
ccs368
Drives: 2023 BMW X1
If you’re really into minimizing interactions, originally I did one swipe down and then two pushes to disable ASS. Now it’s one swipe down and then only one push as I believe I was able to cascade the last button forward so all of this to disable is not so bad all things considering.
abirmaher892.50
nishalp12.00
      12-28-2023, 08:41 AM   #10
SpaceSilver.X1
1554
interesting.... can you explain how this is accomplished?
Thanks!
      12-28-2023, 10:05 AM   #11
abirmaher
abirmaher's Avatar
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
  [0.00]
2018 BMW M2  [10.00]
Thanks!
I would be curious as well.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      12-28-2023, 11:04 AM   #12
SpaceSilver.X1
1554
surely it's possible to disable it permanently using the diagnostic computer at the dealer, but I'm guessing that they will absolutely not do this for liability reasons.
manufacturers(car or phone) really hate it when customers try to circumvent things...
before iOS 16, it was possible for CarPlay to play YouTube videos and even view live video on the Ring door cam app when my jailbroken iPhone 12 Pro was paired to the Lexus infotainment screen.(even when the vehicle was in motion) after iOS 17, nobody has figured out how to do it yet.
abirmaher892.50
      12-28-2023, 03:13 PM   #13
ccs368
Drives: 2023 BMW X1
Thanks!
I’ll be out of the country for 4 more days and if no one else responded, I’ll take a look. It’s very similar to what we currently do by holding the button and sending it to an empty shortcut position but I was just messing around and I believe you have to get further down to the last screen step to disable ASS and I held the button to send it forward. It’s been 8 months too since I did it but one swipe and one touch and ASS is disabled.
      12-28-2023, 04:33 PM   #14
timesone
timesone's Avatar
Drives: 2023 BMW X1
      12-28-2023, 05:09 PM   #15
SpaceSilver.X1
1554
Thank you!
I followed your suggestion and added the "Activate" button to my drop-down menu. So now it's just one swipe down and press to disable ASS. So much easier this way.
can't believe this... after 8 months, I never realized that the "Deactivate this" button could be added as a shortcut.
(edit: apparently this only works for X1 running vintage iDrive 8 software)
      12-29-2023, 07:37 AM   #16
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
For ID9 which the 2024 model should have (at least mine does) holding the deactivate once does not give you the option for adding a shortcut. Anyone found a workaround on ID9?
Follow my builds:
      12-29-2023, 07:55 AM   #17
RNorb
Drives: 2025 X5 M60i, 2024 X1 28i
Same here. Looks like we are stuck with a three step process. It will become an easy routine after a while.
      12-29-2023, 07:57 AM   #18
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
After waiting like 2 minutes for the ID9 to wake up. Super annoyed and underwhelmed with the ID9 system. Hoping for big improvements in future updates.
Follow my builds:
      12-29-2023, 08:09 AM   #19
SpaceSilver.X1
1554
sorry about that, I didn't realize that BMW had taken away the ability to do that for 2024 models with ID9.
abirmaher892.50
      12-29-2023, 08:12 AM   #20
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
Sadly yes. Hoping for updates to improve things soon.
Follow my builds:
      01-08-2024, 07:53 PM   #21
rlynn92
rlynn92's Avatar
Drives: G20 330i,X1 M35i
*sigh* ID9 strikes again.
Do you guys think this aggressive start-stop programming is to prevent wear on the DCT?
      01-08-2024, 11:03 PM   #22
rocketman99
Lurker
Drives: '19 M2C, '24 X1 M35
I don't find it aggressive at all. I think it's milder on the X1 than previous vehicles. I don't know what you guys are doing when you're driving but I barely ever even notice it.
