12-27-2023, 08:12 PM | #1 |
Rep 4
G01 X3 with M4 Wheels
Would it be sketch AF to add wheel adapters and hub centric rings to allow my F82 wheels to fit this 2021 X3? I know this isnt the most optimal idea, but would it work and would it be entirely unsafe? I've ran wheels spacers for years without issue with hard track use . Id imagine on a daily X3 it would fine. Flame away, any one with real insight will be appreciated!
I have several spare sets of wheels for the F82 with new tires already. Save the "just go buy new wheels" lol. I prolly will but would still like to rock these wheels until then. |
12-27-2023, 10:20 PM | #2 | |
Rep 1,833
Drives: 2022 X3 M40i
12-28-2023, 05:10 AM | #3 |
Rep 1,572
Drives: 2022 X3 M40d LCI
There’s a circa 800kg / 1700lbs difference in weight between the two vehicles (depending on the spec sheet you look at) so I’d double check the wheel loading is good also!
Current - 2022 X3 M40d LCI in Brooklyn Grey.
Modifications - AutoID Front Splitter. DTUK Pedalbox Plus. Gloss Black M Badges. 3d Maxpider Kuga Floor Matts & Cargo liner. BMW M-Performance Flow Through Spoiler. Mid-Trunk Spoiler. 15mm Spacers all round. AP Arch Guards. X3M Side Vents. 699M Wheels Gloss Black |
wdeerfield2757.00 Rottweiler4061.00 |
12-28-2023, 10:44 AM | #4 |
Rep 4
It's 5x120 with a 72.6 Hub bore for the wheels that would go on 5x112 with a hub bore of 66.56 for the X3. I'm thinking a wheel adapter and some rings would make it fit. I'd have to test fit to make sure the M wheel are not too wide but they are very close to the same size as the X3M wheels.
12-28-2023, 10:56 AM | #5 |
A family of bimmers
2757
Rep 7,743
I can’t see these fitting with the thickness of a spacer you’re going to need to convert from 112 to 120. Curious to see how it turns out though. Some of the f series wheels would look great on the g series.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
12-28-2023, 11:11 AM | #6 |
Rep 4
Looks like it will be an 1" thick I found another that 18mm. You may be right tho. It may stick out too far. I'll have to do a test fit first . I just got hopeful reading other work X3M's were adding spacers and it worked for their application. I was mainly wanting to make sure using a hub centric ring with a wheel adapter was safe. Seemed questionable, but looks as if others have done it. I'll probably just buy wheels. lol.
12-28-2023, 12:02 PM | #7 |
Rep 7,584
If you use the wheel/tire calculator at the following site…you can get a visual as well as the numerical value (metric) when you compare your old wheel/tire specs to the new wheel/tire specs.
Do remember that if you are adding a spacer to the new wheel…you SUBTRACT the thickness of the spacer from the wheel’s offset. So if the wheel has a 35mm offset and you use a 10mm spacer…the new offset with the wheel & spacer will be 25mm (not 45mm). Compare your old vs new wheel/tire setup at this site: www.willtheyfit.com
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
Rottweiler4061.00 Fassina44.50 |
