01-04-2024, 02:40 AM | #1 |
![]() 154
Rep 233
Music library setup help
Hi
Just looking for a bit of help on the best way of getting music library into the car? I have searched but can't find anything. Its the wife's car and she does not use any streaming services (Spotify etc). Her phone memory is also nearly full (photos / videos). So I was looking to store or upload using USB if possible. Any help on doing this (or any alternative method) please. Thanks |
01-04-2024, 04:17 AM | #2 |
![]() 152
Rep 207
I have a 16GB miniature memory stick plugged into one of the USB C ports with 1000's of tracks saved to it and it works a treat - album, artist, song track (and if available, artwork) all display perfectly - you can shuffle play, play albums or by artist etc - all the things you can do on any other music player app.
My X1 in on ID8 (so I assume ID9 will be just the same in behaviour), and as soon as I plugged in the USB stick, it detected it - I didn't have to do anything to set it up. You can control the memory stick via the steering wheel controls, or the centre touchscreen or the dedicated buttons on the centre console. |
01-04-2024, 11:04 AM | #3 |
Rep 27
This is helpful as I have been looking for a solution for this. Previous car was an X3 which had a hard-drive and easy to upload music via USB and there when needed. Just wondering what make of memory stick you used? Thanks.
01-04-2024, 11:42 AM | #4 |
![]() 75
Rep 197
The trick to finding your way around the music in a SD card is to use the search option. That'll let you navigate the folders and let you set a folder with a lot of other subfolders as the source. It can then play on order or you can set it to shuffle.
I mention this because there is a post somewhere in this forum that says you can't have subfolders . That's inaccurate |
01-04-2024, 05:02 PM | #5 |
![]() 154
Rep 233
Thanks for the replies.....
Which USB port do you use (and does it matter)? I seem to remember on my M2 that music player was from a specific port. And are there any known limitations for the USB memory size? |
Xblmppilot1.50 |
01-04-2024, 08:12 PM | #7 |
I Shoot People For Money
1270
Rep 2,177
Drives: 2023 Portimao MSport X1
As far as I can tell it can read data through either of the USB-C ports, I’ve used either for recording and storing my Drive Recorder footage. I don’t use USB for music though since I just use Apple Music.
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
01-05-2024, 02:35 AM | #8 |
Rep 23
I am using this one:
https://www.samsung.com/us/computing...-muf-256da-am/ Using the driver side usb-c port, and it's out of the way so you won't even notice it's there. |
01-05-2024, 02:38 AM | #9 |
![]() 152
Rep 207
I use a SanDisk Cruzer 16GB - it's really compact.
01-05-2024, 02:40 AM | #10 |
![]() 152
Rep 207
Out of curiosity, I have tried all four ports and they all work. Not sure about the max memory size allowed; mine is only 16GB, but that size still has room for hundreds of tracks.
01-08-2024, 09:31 AM | #13 |
Rep 27
Works a treat. Small SanDisk purchased and music synced. The SanDisk is articulated with an "A" at one end and "C" at he other, meaning it's quite unobstrusive when plugged in. As has been said any USB C port works. On screen able to search Artist, Album or track. Thanks again for the advice and tips.
01-28-2024, 06:09 PM | #14 |
![]() 18
Rep 39
Has anyone worked out how to activate ‘Shuffle’ when using a USB with music files please? I’ve been looking for ages but can’t work it out. I’ve tried voice commands but no joy. I’m on ID9.
TIA
Gone: 1999 E36 316i, 2001 E46 318Ci, 2007 E60 525d, 2014 F32 420d, 1990 E30 320i, 2016 F22 M235, 2018 F20 M140i,2021 G20 320i
Current: 2024 U11 X1 sDrive20i MSport |
01-30-2024, 10:14 AM | #15 |
Rep 27
I'm on ID8 but on the screen when music app open there is a shuffle option.
Danny_Shadow17.50 |
01-30-2024, 12:22 PM | #16 | |
![]() 18
Rep 39
Still getting used to having no drive controller. Thanks again!
01-30-2024, 08:06 PM | #17 |
Lurker
![]() 142
Rep 240
Does anyone else using a memory stick for music find it's very inconsistent for availability? Sometimes the car flat out won't recognize there's a stick plugged in until I do an idrive reset. Plugging in a different USB stick makes no difference in this situation.
02-01-2024, 01:05 AM | #18 | |
![]() 75
Rep 197
02-01-2024, 07:44 AM | #19 | |
![]() 154
Rep 233
I started the thread initially and had loaded up a USB for my wife's X1 (out of interest, music only worked on the front USB ports and not the rears). First time it worked great, then last time it wouldn't show albums and only a handful of artists - but all the tracks (a-z) which isn't much use. I will see what happens next time I'm in it. |
02-04-2024, 03:27 PM | #20 |
Lurker
![]() 142
Rep 240
02-04-2024, 03:33 PM | #21 | |
Lurker
![]() 142
Rep 240
At least I was able to immediately get back in the music library, I assumed it was going to pretend there was no stick inserted like it usually does when that happens. There's no rhyme or reason to it, it just plain sucks. |
02-04-2024, 09:48 PM | #22 |
![]() 75
Rep 197
There's no "moving".... It's just reading the files. Mine works without issue. Sometimes I have to reselect the media but it's no big deal. I don't have the bmw app and always a "guest " in my own car.
