01-04-2024, 06:55 PM | #1 |
Rep 55
I added a subwoofer and here is feedback
Do it. I added an audison active 10-inch sub into the underfloor storage, and now the car sounds better than the Burmester in our e-class cabriolet and as good as our x7 m50 in theatre mode (which is my favourite). It really does improve the sound quality alot once you tune it correctly (it was too much bass at first, but i tuned it to my favourite songs). And it somehow works with the inbuilt bass-slider incase you find its too much bass! it cost 1500aud, fitted, installed and tuned and is a 10/10 recommend install if you feel like bass is an issue.
The only downside is that at low volumes it can feel like the bass is coming from the back of the car, but at 50% (i used to max vol in order to vibe, but 50% is the sweet spot that i enjoy all my music from different genres) because the bass harmonises with the surround sound. If you had any questions feel free down below! |
01-04-2024, 08:11 PM | #2 |
I Shoot People For Money
1236
Rep 2,148
Drives: 2023 Portimao MSport X1
I have this lying around that I self installed on my previous 4 series. It was great in there and presumably would sound just as good in the X1, I’m just too lazy to run wires from the front to the back lol. Most likely I’ll be putting it in my new daily driver instead since the install is much simpler.
JL Audio
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
01-05-2024, 12:55 PM | #3 |
Rep 64
This sounds really intriguing. I'm happy with the sound quality for what's there but could use some more low end thump.
What did the installation process involve? Did it wire into the existing amplifier or did it involve installing additional hardware? Also how did you get power to it? Was this with the Harmon Kardon speakers or the base model? |
01-08-2024, 07:33 PM | #4 | |
Rep 44
01-15-2024, 05:22 PM | #5 | |
Rep 55
spmcewen20.50 |
01-15-2024, 05:23 PM | #6 |
Rep 55
The shop I used was house of soundz in australia, newcastle. Maybe you could give them a call, because i am no electrician or mechanic sorry.
01-15-2024, 09:38 PM | #7 | |
world's slowest BMW driver
1558
Rep 1,003
Drives: U11, G60, W211, AZ20
Unfortunately, the U.S. X1 has a spare tire and tools in the boot. I plan to leave the spare in the garage and get a BMW mobility kit. Do you happen to have the part number of the BMW mobility kit that came with your X1 in Australia? Thanks! |
11-26-2024, 11:44 AM | #8 | |
Rep 43
12-01-2024, 10:02 AM | #9 |
Rep 3
My unit came with the most basic sound setup from factory. Went with focalinside speakers and the Audison Prima 8 inch woofer (fits nicely underneath the trunk). This is powered with MatchUp 8 DSP (sorry no pics for this). Vast improvement over the disappointing stock system.
quirksandfeats10.50 |
12-04-2024, 09:52 AM | #10 | |
Rep 5
1. Do you know where they got the power for the active subwoofer? Did they stretch a wire all the way from the battery in the engine bay? 2. Where is your subwoofer getting its signal from? Hi-level input from stock speakers? Did they tap into the wiring of the original underseat woofers? Or is there somehow a way to get a signal directly from the amplifier? If you have any pictures, that would be a massive help. TIA |
12-04-2024, 09:57 AM | #11 | |
Rep 5
There are a few flat-body (underseat) subwoofers I have seen on the market that have a height of ~7cm. However, with that there is absolutely no gap left top/bottom of the subwoofer. |
quirksandfeats10.50 Tazz20.50 |
12-07-2024, 05:42 PM | #14 | |
Rep 55
12-07-2024, 05:45 PM | #15 | |
Rep 55
2. yes it is hi-level input from stock speakers, given the size (and budget) limitations i chose a subwoofer with a built in amplifier so my answer is yes but really no? |
12-07-2024, 05:47 PM | #16 |
Rep 55
just to note I have the subwoofer pointed up (even if this causes cone sagging) because it rattles the trunk and loses oomph if pointed down (maybe the underfloor is thin???)
12-07-2024, 05:47 PM | #17 | |
Rep 55
just posted that pic |
12-20-2024, 01:57 PM | #18 | |
Rep 5
I'm curious: why did you opt for a separate sub instead of upgrading the woofers under the seat?
12-23-2024, 03:08 AM | #20 |
Rep 3
12-23-2024, 10:28 PM | #21 | |
Rep 65
Thank you so much! I didn't think this was available and I've wanted since day 1. |
