BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) Unlock all doors not working
      01-10-2024, 05:03 AM   #1
Rusty the Snowman
Drives: BMW X1 xDrive 23i M Sport
Hi all - new member here! I got my X1 2 weeks ago.
I have set the key to unlock all doors but it doesn't work on the driver's side.
If I put my hand under the passenger door handle all the doors unlock, but doing the same under the driver's door handle only that door unlocks.
I have iDrive 9 11/2023.25 installed.
Any suggestions please?
      01-10-2024, 05:18 AM   #2
FZI89
FZI89's Avatar
Austria
686
Drives: BMW iX1, U11
Here you go!
These instructions are for iDrive 8, but should be similar. If not, check your drivers manual
timesone241.00
metapod30.00
      01-15-2024, 06:40 AM   #3
Rusty the Snowman
Thanks. I have double-checked all my settings, changed them and set them back and still no luck. Seems like it may be a bug.
      01-15-2024, 11:33 AM   #4
BMWZ4
BMWZ4's Avatar
1926
Drives: '23 X1/'23 Allroad Progressiv
Curious if using the fob, the digital card or your mobile?
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
      01-15-2024, 06:11 PM   #5
FlashMonkey929
I Shoot People For Money
FlashMonkey929's Avatar
1222
Drives: 2023 Portimao MSport X1
2003 BMW 330i ZHP  [0.00]
2023 BMW X1  [10.00]
Have you tried touching the door handle twice in a row?
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold-
2020 430i Estoril Coupe MSport -returned-
2023 X1 Portimao, Msport, Premium
2003 330i Imola Red ZHP 6 Speed
      01-15-2024, 08:25 PM   #6
PatL
Drives: 2024 X1 28i
I am seeing the same when unlocking with the phone from a distance. Despite the setting to unlock all doors, only the driver's door is unlocked.
However, when the setting to unlock all doors at the end of the trip is on, all the doors get to be unlocked as expected at the end of the trip.
      01-16-2024, 05:21 AM   #7
Rusty the Snowman
I’ve tried it with the fob and the digital key on my iPhone.
      01-16-2024, 05:23 AM   #8
Rusty the Snowman
No, but I will later! That wouldn’t be how I’d expect it to function, but if it works then that’ll do.
      01-16-2024, 05:27 AM   #9
FlashMonkey929
1222
2023 BMW X1  [10.00]
I’m actually not sure if that’s how it works, but I remember one of my cars was like that. On my digital key with my phone, all my doors unlock at once
      01-16-2024, 10:55 AM   #10
JeffH
Drives: BMW X1
I have exactly the same on my new X1 with iDrive9. I had the garage have a look and this is the way BMW now set it up. Apparently it is a security feature to prevent all four doors being opened by mistake. You either have to double click the key to open all doors or use the interior button after opening the driver’s door. However, if you hit unlock on the My BMW phone app it unlocks all doors. Strange logic!
      01-16-2024, 11:10 AM   #11
Rusty the Snowman
If that’s the case then the id9 settings for Door need updating. As per the first reply above, I have it set to unlock all doors. The other option is drivers door only. The “security feature” explained by the garage is over-riding my settings!
      01-17-2024, 05:35 AM   #12
Rusty the Snowman
Didn't work
      01-18-2024, 08:08 AM   #13
markronnie
BMW Owner
markronnie's Avatar
Drives: 2024 BMW X1 28i
2024 BMW X1 28i  [9.00]
For security reasons I’ve always set mine to just open the drivers side door. Then open the others using button on interior door panel.
This being my first BMW & having it just a few weeks, I can only compare it to my prior ACURA’s. They had a feature that could manually open all doors when you wanted to by touching the back door on drivers side with the FOB close by.
BTW within days of getting my 2024 X1 28i I changed the setting from opening up door(s) as I approached to opening when I touched either front door with FOB. I did this to avoid the constant opening/closing of doors & folding mirrors when I walked into my garage. Also a couple of times it did not recognize which of the 2 FOB’s approaching was the driver establishing settings that were not the driver at that time. Frustrating when the seat position moves so far up my knees hit the dash. (My wife is 8” shorter)
timesone241.00
      01-19-2024, 06:20 PM   #14
PatL
Drives: 2024 X1 28i
With the settings set to unlock all doors:
- unlocking at a distance with the phone or the fob presence unlocks the driver door only,
- unlocking from the digital wallet on iPhone unlocks the driver door only,
- unlocking from the BMW App on the iPhone does unlock all the doors
- unlocking with the fob by pressing once unlocks only the driver door, but twice unlocks all doors, but this is "old" behavior.
      02-16-2024, 11:39 AM   #15
Rusty the Snowman
I've found the answer (well, it's a theory I read in another forum that makes logical sense anyway).
The functionality works as if it is LHD. It doesn't work for me because I'm in the UK with a RHD car and BMW haven't coded for that yet.
Hopefully it'll be included in a future software update.
      02-16-2024, 12:22 PM   #16
SpaceSilver.X1
world's slowest BMW driver
1554
Drives: U11, G60, W211, AZ20
one day, BMW will finally figure out how to make the center armrest cover open from the right for RHD cars.
      02-16-2024, 12:38 PM   #17
timesone
timesone's Avatar
Drives: 2023 BMW X1
Every bmw I’ve own the center armrest cover hinged from the back… if it ain’t broke don’t fix it
      02-16-2024, 12:40 PM   #18
Zee
Drives: F44 M235i GC + U11 X1 M35i
I collected my x1 m35i on Sat (car came with iDrive 9 on 11/2024.42.) and it did this twice - exactly the same problem only the drivers door and then when i went to the passenger it unlocked all.
I went to door settings and ticked it to drivers only and then back to all - been fine ever since.
      02-16-2024, 02:31 PM   #19
timesone
timesone's Avatar
Drives: 2023 BMW X1
are you saying that your 2023 X1 also has the center armrest hinged from the back? did BMW make this only for the Canadian market only?
I drive into Windsor to buy several boxes of Corn Pops once in a while... because the Canadian version of Corn Pops is way better than the US version.
Pre x1
      02-29-2024, 07:25 PM   #20
///JJM
Drives: BMW X1 M35i
Have a 24’ M35i and had this same issue with Comfort Access only unlocking the driver’s door. Had my ID9 Lock/Unlock settings set to unlock all doors, but still was not working. Discovered it was the Apple Digital Wallet key causing the issue. If you’re an iPhone user, go to your Wallet>BMW key>Info button(Top right corner). Disable ‘Passive Entry’ and the Comfort Access will work as setup in ID9 settings.
      02-29-2024, 11:23 PM   #21
08-335xi
Drives: 08-335xi sedan
Had a similar issue when we first received our M35i. Found that you had to link your profile to the digital key, PAAK and each individual key fobs to get the setting to be retained. The setting to unlock all four doors and many other settings are based on which device is detected when the door is unlocked.
      09-30-2024, 10:15 AM   #22
philwebb
Drives: BMW X2 M35I
New X2 for 6 months had the same issue all doors do not unlock, key fob needs associating with the profile.
