01-12-2024, 05:55 PM | #1 |
Rep 212
Lowering springs for front only, is it unwise?
Car is G80 M3 Competition
I only have a gripe with the front fender gap, as the rear rims are 20”. Also, I haven’t seen how deep the wheels stick in, so if I wanted spacers, what setup would you recommend? |
01-12-2024, 06:04 PM | #2 |
Rep 472
Yes. It will affect the balance of the car. A friend of our from our track club did that and it was so off balance on the track. Went back right after. Probably a more extreme case, but still makes the same point. Do all or none, but don't mix it. It causes suspension difference between front and back
01-12-2024, 06:10 PM | #3 | |
Rep 506
Pretty sure the Eibach pro kit for G80 is front springs only. On spacers - most do 12 all around for 12 in back and 15 in front. |
01-12-2024, 06:13 PM | #4 | |
Rep 212
What it I do spacers for front only, to match it with the rear wheels which already have good protrusion? |
01-12-2024, 06:25 PM | #5 | |
Rep 506
Spacers - if your wheels are stock, somewhere around 12-15 range/front is what gets most people pretty flush w/ fender. But you may have to experiment there. |
01-12-2024, 06:27 PM | #6 | |
Rep 212
01-12-2024, 06:30 PM | #7 |
Rep 506
01-12-2024, 06:36 PM | #9 |
Rep 212
01-13-2024, 05:40 AM | #11 | |
BimmerPost Supporting Vendor
2045
Rep 530
On the road just front springs are perfectly acceptable. Would the BMW M test driver be slower on a ring lap with just front springs? Maybe but I’d not be near that time in a million years and it’s not how I’d be driving the car. |
dini_g80188.00 |
01-13-2024, 09:47 AM | #12 |
Rep 1,779
I have the H&R Sport kit but installed fronts only. No issues. I don't track so I can't speak on that. I do rub quite a bit but that's due to a combination of the drop, 15mm spacers, and square 826M's.
01-14-2024, 08:47 AM | #13 | |
Rep 506
There is a good video (for x-drive) somewhere from the guys in Raleigh, NC about putting in front springs without a full front suspension disassembly - in short, you put the car on stands, jack up the front suspension/a-arm on one side and remove strut nut and top mount - then slide the top coil off the spring over the strut shaft and then basically screw the coil off of the strut. It makes it MUCH easier. Do a search. FYI - hope that helps. |
01-14-2024, 09:56 AM | #14 |
Rep 6,840
