BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) M sport brakes swap on X1 U11
      01-13-2024, 05:54 PM   #1
Spyros E81
Spyros E81's Avatar
Greece
275
Drives: BMW X1 U11 Sdrive 18i
The first mod on my X1 done with the upgrade of the front brake system.I bought a pair of blue front calipers that I resprayed them in BMW Space Grey A52 colour.After with a new set of brake discs (360mm Ferrodo )and pads ( Brembo ) we putted on.All fits perfect and works as from factory selection.Soon I will schedule to change the rear brake system.
      01-14-2024, 11:57 AM   #2
richiro
Drives: '24 X1 M35i
very nicely done!
where did you source the rotors and pads from if you dont mind sharing?
what were the part numbers?
      01-14-2024, 12:00 PM   #3
Spyros E81
Spyros E81's Avatar
Greece
275
Originally Posted by richiro View Post
very nicely done!
All parts are same with those of F40/F44 M135i/M235i ,F60 Countryman Works S
richiro318.50
      01-15-2024, 09:17 AM   #4
radrads203
Drives: 2014 F15 X5 30d
Mate, can you provide more informations like P.N. for the calipers and brake disc? Are yours direct bolt on? Thanks mate
      01-16-2024, 03:25 PM   #5
angel_grin
angel_grin's Avatar
Australia
9
Drives: m235i
Nicely done! Share part numbers please
      01-17-2024, 09:06 PM   #6
richiro
Drives: '24 X1 M35i
Hi, could you confirm if the M sport brakes you bought were marked with brembo anywhere? Just trying to see what other compatibility is available for this set up since you have seen the parts unattached and then installed on your car.
      01-18-2024, 06:22 AM   #7
ajsti24
ajsti24's Avatar
39
Drives: U11, S209, 8Y-S3
Here are the part numbers, just verify with your local dealership.
34106888629 Brake caliper front left
34106888630 Brake caliper front right
34106889266 Brakepads front
34106884001 360x30 Brakedisc front left
34106884002 360x30 Brakedisc front right
34106877547 Brake Protection plate front left
34106877548 Brake Protection plate front right
34206895367 Brakecaliper rear left
34206895368 Brakecaliper rear right
34206895371 2pcs Brakecarrier rear
34216799371 330x20 Brakediscs rear
34216860007 Handbrakeaktuator left
34216860008 Handbrakeaktuator right
34206886730 2pcs Brake Protection plate rear
FZI89752.50
metapod30.00
      01-18-2024, 04:00 PM   #8
Spyros E81
Spyros E81's Avatar
Greece
275
some photos of them
      05-23-2024, 01:15 AM   #9
JUN WOOK BANG
JUN WOOK BANG's Avatar
South Korea
20
Drives: BMW x1 xdrive msport 20i(24)
Hello. Is BSI (BMW warranty repair) possible after replacing the msports brake?
