01-15-2024, 03:01 PM | #1 |
Rep 31
BimmerCode coding issue
I tried to code auto/start stop off, 5 times turn signals and no hazard lights on harsh braking and none of the changes have worked. I used the same process as I have done with my F87 and Bimmerocde showed a successfull coding message but once disconnected, the coded changes weren’t there. Has anyone else had the same? Maybe BMW have found a way to stop aftermarket coding on the latest cars?
01-15-2024, 05:05 PM | #4 |
Rep 249
Drives: M2 G87 Brooklyn Grey
Did you code from the M2 or M3. I believe that there are more options under the M3. I can tell mine worked because my ambient lighting is purple.
01-15-2024, 06:53 PM | #5 |
Professor
2334
Rep 1,862
Drives: '23 M2 & '22 X3 M Competition
I'm having issues connecting after it connected once. I was able to code the B&W audio and no warning message on the screen at start up.
Re: auto stop/start, you don't have to code it off, you can program it off for both M buttons & once you hit the button to turn it off, it doesn't come back on for any drive mode. |
M2compcharlie55.50 |
01-15-2024, 10:07 PM | #6 |
Rep 130
I’m sorry to ask but did you actually check your settings in idrive after coding? Like 5 blink turn signal doesn’t actually make your turn signal blink 5 times, it just gives you that additional setting under your 3 times. You still need to go into idrive and enable it…
Just a thought, as it confused me for a bit too!
Whoever said "money can't buy happiness" clearly never drove an M2.
01-18-2024, 11:31 PM | #8 | |
Rep 755
01-26-2024, 01:17 PM | #9 |
Professor
2334
Rep 1,862
01-26-2024, 01:44 PM | #11 |
Professor
2334
Rep 1,862
