01-26-2024, 12:26 AM | #1 |
167
Rep 599
Genuine G80 and G82 M Carbon ceramic brakes. Competence has never looked this good!
We just received a factory M Carbon Ceramic brake system designed specifically for the BMW G80 M3 and G82 M4, and we couldn't wait to unbox it and take a look! This lil' beast is the highest-grade braking setup offered by BMW. It features front 6-piston matte gold calipers paired with 400mm carbon ceramic brake discs, and rear 1-piston matte gold calipers paired with 380mm carbon ceramic brake discs.
Carbon ceramic discs not only possess exceptional wear and heat resistance but also offer significant weight reduction due to their lightweight design. In simple terms, besides providing stronger braking performance, they also contribute to overall handling, steering, and acceleration. If you're someone who seeks a higher level of driving experience and craves the sensation of racing-like performance, I can assure you that this is a highly worthwhile upgrade for your vehicle. With its outstanding durability and reduced weight, you can expect enhanced braking capabilities and improved overall driving dynamics. Whether you're pushing the limits on the track or simply enjoying spirited driving on the open road, this high-performance component will elevate your driving experience to new heights. Here's more on this product: https://icarmix.com/product/genuine-...m3-g82-g83-m4/ And here's what you can look forward to: |
01-30-2024, 12:44 PM | #2 |
Rep 241
Are these direct swap for the OEM steel brakes? Anything else needed?
Peter
2024 BMW M3 CS -- 2021 STO UGR TT -- 2019 McLaren Senna -- 2021 McLaren 765LT -- 1997 Toyota Supra Turbo -- 2006 Ford GT -- 2022 Lamborghini Urus
snyder268152.50 |
01-30-2024, 08:23 PM | #3 |
167
Rep 599
02-08-2024, 04:44 AM | #4 |
Mad Linux Guru On The Loose
1131
Rep 5,404
Its a simple mechanical swap, but CCB kit will require coding so that the various chassis controllers would know what brakes are installed.
02-10-2024, 03:28 AM | #5 |
Rep 120
Only $20k!
forcefed2602.50 Vectors2final1543.50 |
02-19-2024, 09:43 PM | #10 |
167
Rep 599
Tags |
ceramic brakes, g80 m3, g82 m4, hong kong, icarmix, m performance brake |
