01-28-2024, 01:06 PM | #1 |
Rep 22,617
If you want to drive your BMW fast..
Worth taking in especially if an M driver
@7:28 Last edited by M5Rick; 01-29-2024 at 06:32 AM.. |
01-29-2024, 08:58 PM | #2 |
Rep 14,310
Drives: G82 M4C X-Drive
Garage List 2025 BMW M2 [10.00]
2022 G82 M4C X-Drive [9.89] 2018 F80 M3 CS [9.90] 2018 BMW i3 REx [5.00] 2015 BMW i3 REx [0.00] 2016 BMW F80 M3 [7.29] 2016 BMW F30 340i ZTR [10.00] 2013 BMW F30 328i [0.00] 2006 Audi S4 25Quattro [7.00] |
Good stuff on looking ahead in corner entry. That's one of the number 1 things they teach you in high performance driving. Also, keep that head on a swivel. Turn your head into the corner. A hairpin corner should have you looking out the side windows, for example.
As far as "keeping up with friends" every race car drivers know that in order to be fast, you need to be really good a braking. Most people think being faster in the corner will let them catch up without considering the grip limitations of their car. That's when they lose control. Instead, think about reducing the brake zones so that the car is at speed a bit longer. That means reducing coasting time where drivers let off the throttle, coast to the corner, then apply the brakes. In normal street driving, we normally apply the brakes gradually at first, then increase pressure as the car gets closer to the corner or stop light etc. In high performance driving, it's the exact opposite. You are on the throttle until your brake zone begins, then HARD initially on the brakes, then trail it off as you reach the apex. This leads to shorter braking distances, longer straights at speed, and increased corner stability. HOWEVER, this is generally dangerous on canyon road, as misjudgments on that braking zone are way too easy. It's more usable on the track, where you are familiar with the track and know exactly when to brake. Additionally, this method is very hard on the brakes, and factory pads have a high chance of fading in short order, which could cause the brakes to perform so poorly as to be dangerous. Tire Pressure: Pressure is proportional to temperature in our tires. Cold tire temps are generally fine since street driving doesn't reach extreme temperatures that you get on the track. However, for optimal tire performance, tire temps should be taken HOT, and adjusted not to be above the optimal temp/pressure for that tire. In general, high performance summer tires don't like to be above 40psi hot. Good stuff on corner exit. Here's a easy metaphor to help visualize throttle application. Picture a string attached to the bottom of the steering wheel and the gas pedal. With the steering wheel turned, the string will not allow the throttle to be fully engaged. Only as you straighten the wheel does the string allow you to apply more throttle.
2022 G82///M4 Competition X-Drive - KW-HAS, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 Ordered • 2025 ///M2 |
01-30-2024, 07:41 AM | #4 |
Curently BMWless
22050
Rep 747
I assume there is high-performance driving instruction available in the UK, Rick, is there not?
'25 M850ix GC (Ordered)
BMW CCA 30 years |
M5Rick70822.00 |
01-30-2024, 01:55 PM | #5 | |
Rep 22,617
Once in a while I go to a place where you can drive V8 AMG cars, at Mercedes World in Surrey. There for an hour you can drive these RWD cars around a test track at WOT where possible and the instructor advises you of what you could do better, then there's a wet skid control work out around a roundabout. He gave me 8/10 the first time I went so was quite pleased with myself. The entry and exit of a turn is important and having the right entry then gradual throttle coming out of the turn building to FT when the front wheels are straight is the key to getting a good lap, as the chap in the vid above explains. On the public road you are then more sure of yourself reading coming situations better and when approaching another car to overtake you quickly take in factors like what car it is and what you can see of that driver with the way its being being driven before making your move. |
01-30-2024, 02:56 PM | #6 | |
Rep 692
01-30-2024, 04:02 PM | #7 |
Rep 22,617
eugenebmw2169.50 ///M Power-Belgium72488.50 |
01-30-2024, 05:51 PM | #8 |
Rep 692
I heard so many OP on this forum are talking about modified this and that on their G8x in order to to drive fast on track. If you ask me, it is a joke. If you don't have the proper tracking skills, even a miata can beat you at every apex turning Instead of spending the $$$$ on modified your cars, I will sign up for more track days. Learn the skills and have fun.
01-31-2024, 04:40 AM | #9 | |
Rep 22,617
01-31-2024, 12:25 PM | #10 |
Rep 692
The best way is having an instructor sit in your car with you while driving on track for a few track days. You will be surprise how many mistakes you made. The hardest parts are learn from the mistake and re-learn the correct way to drive.
01-31-2024, 01:23 PM | #11 | |
Rep 22,617
I added a brake pedal to the left extension so I can left foot brake keeping my right foot over the gas pedal more. When you get used to it you should get quicker lap times as the correlation between braking and throttle will be more positive. Here's Mick's take on braking and how to master it better. |
eugenebmw2169.50 |
01-31-2024, 01:49 PM | #12 | |
Rep 692
M5Rick70822.00 |
01-31-2024, 02:46 PM | #13 | |
Rep 1,795
I would like to see you brake with your left foot on a twisty road, on 6MT |
eugenebmw2169.50 |
01-31-2024, 05:31 PM | #15 |
Rep 692
Talk about hand position on the steering wheel. I saw so many Porsche, Lambo and super cars drivers are holding their steering wheels in 11 and 1 o'clock position. One thing for sure, money doesn't fix stupidity. Stupid is forever
M5Rick70822.00 |
01-31-2024, 05:35 PM | #16 |
Rep 692
01-31-2024, 06:00 PM | #17 |
Rep 1,795
I am sure that you will not go faster using your left foot to brake in a 6mt on a twisty road, I would dare to say that you will even be slower.
1heckinboi56.00 |
02-01-2024, 12:15 PM | #19 | |
Rep 692
There is a reason for everything. Last edited by eugenebmw; 02-01-2024 at 03:59 PM.. |
M5Rick70822.00 |
02-01-2024, 12:20 PM | #20 | |
Rep 692
As I always say, it is not the car make you fast, it is the driver |
M5Rick70822.00 |
02-01-2024, 01:23 PM | #21 |
Rep 1,403
02-01-2024, 04:08 PM | #22 |
Rep 692
