01-30-2024, 06:13 AM | #1 |
Rep 59
Vorshlag Camber Plates and Ride Quality
Have the Vorshlag camber plates with KW haas installed and my ride quality is super harsh and I would not have noticed until I rode in my brothers g87 with eibach springs.
Do you think it’s because of the camber plates or the haas? Spoke to my installer and he said mine don’t have any preload on the springs versus the eibach and that’s why but anyone else experience this? |
01-30-2024, 07:40 AM | #2 | |
Rep 3,036
I have port installed M Performance HAS (which is manufactured by KW for BMW) and ride is not harsh at all. Are you lowered all the way? Possibly how you have the camber plates set? |
01-30-2024, 07:56 AM | #3 | |
Rep 268
Did your brother swap just the springs?
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
01-30-2024, 08:21 AM | #4 | |
Rep 3,036
The plates could definitely have an effect on the ride, depending on the ultimate angle they are set at (and if lowered all the way). |
01-30-2024, 09:31 AM | #5 |
Rep 268
ummmm ya, I am not sure if you are being argumentative here but that's basically what I said. But to add some clarity- the mere presence of camber plates should not affect ride quality assuming everything is installed correctly but other settings like ride height (set by the HAS) or alignment settings like camber (set by the camber plates and the OEM camber adjustment points) can affect ride quality. If the OP's car is aligned to proper spec and the 8 bolts and the top nut are tightened correctly on each camber plate I would look at spring rate and ride height.
2022 M850i
01-30-2024, 10:10 AM | #6 |
Rep 59
its not max lowered at all, but the argument that the tech made was that when the car is at the height its at right now there is no preload on the springs but if he raises it, there is. Made no sense.
Had the tech at BMW look at it and he said all looked good but the ride just doesnt feel as my brothers and all he did was the springs so no adjustments there |
01-30-2024, 10:57 AM | #7 | |
Rep 3,036
Well, you said camber plates wont make the ride harsh. I responded by saying yes, they can (which is not argumentative but a factual response), depending... |
01-31-2024, 11:46 AM | #9 | |
Rep 268
What are your alignment specs? What is the spring rate of your brother's Eibach springs? Did he make any other changes?
2022 M850i
