02-01-2024, 01:58 AM | #1 |
Rep 6
18x11 square setup anyone?
Trying to do a 18x11 square setup for my track use, anyone know what offset I would need for 295/35/18 without getting camber plates if it’s possible…?
Thanks! |
02-01-2024, 02:35 PM | #3 |
Rep 150
295 on a 11 is a waste.
Can run a 295 quite happily on a 10.5 no reason to go to 11 theres off the shelf wheels that fill that role. Apex 18x10.5 VS5RS If wanting to go 305-315 11 is worth it. No reason to re-invent the wheel. -GT3M2 |
laughMan82.50 |
02-01-2024, 06:03 PM | #4 |
Rep 268
ahhhh I see what you did there
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
GT3M2177.00 |
02-02-2024, 11:32 AM | #5 |
Rep 10
Can a 305 on a 18x11 fit with no fender rub on the front?
02-02-2024, 11:45 AM | #6 |
Car Geek
3708
Rep 3,621
02-05-2024, 09:18 AM | #7 |
Rep 150
02-05-2024, 04:54 PM | #8 |
Rep 1,807
You really don't need 305 fronts on this car. Spend that money taking high performance driving lessons from a properly accredited instructor.
2023 G87 M2 - Toronto Red | 6MT | M HAS | CF Roof | BMW 826M Forged Wheels | Mishimoto Skid Plate | Active Autowerks Single Midpipe
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is |
02-06-2024, 02:20 PM | #9 |
Rep 6,799
It would need changes to the liners for clearance. Also have you looked at tire options? 305/35-18 has very few options in the track tire categories. Toyo r888r and nitto NT01 are some of the few tires available. Frankly, I think you'd be faster with 19x11 ET22 and a 305/30-19 which has more 200 tw track tire options.
We make an 18x10.5 ET18 that works well with 295/35-18s which have more tire options. The main reason I haven't opted to produce an 18x11 is that there are not good models tires available in appropriate sizes that take advantage of the wider wheel relative to a 10.5. -Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
02-07-2024, 06:38 AM | #10 |
Christmas Poo
1089
Rep 1,203
This is some serious truth right here. You can look at wheels all day long but there are certainly sweet spots in diameter that have plenty of tire choices, go up an inch and near unch in choice. When choosing wheels I now start at tires I want then work my way back to wheel size and offset from there.
lithe31.00 |
02-09-2024, 04:01 AM | #11 |
Rep 4,526
OEM GT4 G82 wheels
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
02-09-2024, 12:20 PM | #12 |
Car Geek
3708
Rep 3,621
https://www.apmotorsport.co.uk/produ...4-wheels-11x18
They require different uprights (camber plates would likely work if the ET8 offset clears the OEM struts) and different wheel arch liners for the specified 305/680-18 tyres to fit without body contact (closest equivalent road tyre is 305/35-18). The wheels are also designed for the M4 GT4 carbon ceramic brakes, so clearance on the steel brakes would need to be checked. Last edited by aerobod; 02-09-2024 at 12:26 PM.. |
Ravenseal2883.00 |
02-09-2024, 12:31 PM | #13 | |
Rep 4,526
As you rightly say the ca. 1 1/4” added poke will be the challenge. M4 CSL swivels/hubcarriers likely would work to add front camber and opt for say 295/40/18 front tyres
02-13-2024, 11:02 PM | #14 |
Rep 6
