BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) 2024 X1 M35i suspension/ride quality
      02-29-2024, 05:36 AM   #1
Zee
Drives: F44 M235i GC + U11 X1 M35i
Those with a X1 M35i what's your ride quality like?
My 2024 X1 M35i has covered 500 miles and is 2 weeks old. I have 20" with Pirelli P Zero and on normal roads I find it rather bouncy when driving. I do feel every crack/bump/manhole cover etc. slightly less noticeable on freshly resurfaced roads.
I know the low-profile and 20" wheels will play a factor but with my 2023 X1 23d on 20" felt a lot smoother on the same roads.
I've had a play with adjusting the tyre pressures which has helped a bit and im starting to think there might be suspension fault or something else?
Any advice would be appreciated before booking it into the dealers
      02-29-2024, 05:42 AM   #2
Tsapetro
Tsapetro's Avatar
Drives: Bmw x1 23i
It’s an m performance model with 20inch wheels what do u expect? Obvious it’s going to be harsh on most roads
      02-29-2024, 06:22 AM   #3
MontyB1
Drives: BMW X3
Are both models that you have M-Sport in which case they should be very similar, if one is an X-Line then that's your answer.
      02-29-2024, 06:31 AM   #4
Zee
Both are M-Sport 20" only difference was on the 23d the tyres were continental
      02-29-2024, 06:47 AM   #5
Zee
On my m235i now that's harsh not bouncy as I am describing but I wouldn't compare 2 as the X1 is a lot higher.
      02-29-2024, 12:33 PM   #6
Zayken
United Arab Emirates
34
Drives: IX1 30e / f40 118i
Damn, you are not joking.
Dont go to the dealer. The car by defalut is tuned to be stiffer.
Its an M performance car, so dont compare it with the other X1
Im sorry if you dont like it.
There is a very recent review of iX2 and X2 M35 by autogefuel (in english) and its describing exactly the same thing.
M35 much stiffer than iX2 m sport
Zee10.50
      03-01-2024, 12:53 PM   #7
Zee
That’s the thing, it doesn’t feel stiff but more a bouncy float left and right wobble when driving. My 23d M Sport also had M Adaptive Suspension running 20s and I covered 5k miles and was fine while on the M35i was only noticeable after 2 weeks ownership and 400 miles in.
      03-01-2024, 02:17 PM   #8
SpaceSilver.X1
world's slowest BMW driver
1554
Drives: U11, G60, W211, AZ20
I drove the M35i for a couple of days. With its 20-inch wheels, I actually thought the ride was somewhat more comfortable than my xDrive28i with M Sport suspension on 18-inch wheels. Although I read somewhere that it could be due to the fact that the Pirelli P-Zero all-season tires had a very harsh, bouncy and non-compliant ride. (which I kind of knew because the 19-inch Continentals on the dealer's demo X1 with standard suspension also had a better ride than my X1)
      03-01-2024, 04:33 PM   #9
richiro
Drives: '24 X1 M35i
I would say the type of tires make a big difference.
The car does settle in more after the 1k mark.
I agree the initial ride is quite firm, especially with sport seats.
